TH-58PZ750U Panasonic Plasma TV, problem a black bar, from the top left side of the screen (one foot from the left side), approximately 3" wide extends from the top of the screen to the middle of the screen (half way down). This model tv appears to have buffer board on the top, bottom, left and right sides. I believe that (looking from the back) the top right board has a problem, (TN PA 3996), that is causing the issue. Any assistance will be appreciated.
  • Trent Davenport
    Trent Davenport Oct 12, 2013
    I removed the ribbon closest to the black bar from the tn pa 3996 board, cleaned the connection, the issue with the bar was corrected.
  • Trent Davenport
    Jpeg of the black bar.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Faulty screen-shots to plasma TVs are given. You can compare it to that of your TVs' and make sure about the fault. Details too is there.
Posted on Oct 12, 2013
rlamkin
  • 44 Answers
SOURCE: Samsung plasma tv hp-r4262
The x drive board is bad in the area you see as black. OR the cable came loose.
Posted on Jul 04, 2008
DOCTOR VIDEO
  • 131 Answers
SOURCE: BLACK LINE PLASMA TV
most likely this is your y or x sustain boards and if that does not fix it . it could your pdp panel cost varise on part . The cost of your pdp panel is very expesive this th has lots of problems. I would call your local tv shop and have them give you a estimate.First ask thme how much they charge for a estimate. good luck.
Thanks doctor video
Posted on May 17, 2008
  • 380 Answers
SOURCE: Green vertical bar on right side of plasma TV screen
You could have one of three problems. One is really expensing to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went back. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable and clean it off a bit and put it back. If its still there, you have a deeper problem.
Posted on May 27, 2009
  • 112 Answers
SOURCE: Problem with TV image, sound is OK. My Panasonic
if you ask me the panel its dead to lose the half of the screen means no addressing logic board dead or in the most of the cases panel :( i`m not sure but if you add some images :D with signal is it the same ?
Posted on Sep 22, 2010
rylee_smith
  • 8619 Answers
SOURCE: MODEL: TH-50PZ85U I HAVE A VERTICAL
Hi
Thanks for using FixYa. As Plasma TV is a very hard working device so it produces lots of heat and around 75% issues in Plasmas are caused due to overheating. To start with you'll have to open the back of the unit and check for any bulged/bad capacitors on Y and Z-sus boards. As the sound is working fine so it seems that the power supply is fine, also check the control board for any bulged capacitors. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
Hello, I have a Panasonic TH-58pz750u plasma tv, vertical bars appeared at lower right quadrant of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 24, 2014 | Televison & Video
On a 58" diagonal plasma, I have an approximate 3-1/4" wide pink vertical bar in the lower left corner of the screen. It does not go all the way to the top of the plasma, it stops mid-way on the scre
There is some connection defects. If you wish to know more about these kind of fault to plasma displays, check this link. There is illustrations to compare with, which cannot be included by this window.
Feb 25, 2013 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
There are 6" wide gray bars on each side ot the TV
The grey bars signal that the source image is originally in 4:3 format - if you are using a box of some kind get in its menu and change the format from there to 16:9. The black bars appear when a 16:9 image is sent to a 4:3 format in Letterbox mode - leave it like that or the Pan and Scan mode will chop the sides.
Jul 20, 2011 | Panasonic Viera TH-42PX80U Plasma TV
My TH-50PZ80U has developed a vertical black bar, about 3 inches wide, at the far left margin of the screen. How do I get rid of it?
Need to know if the bar is cutting off picture or if the picture is being squeezed to fit the remaining space
Nov 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Black bar left side of screen 200mm wide on a viere 50
If you can open Plasma then open and clean all connector & refit properly mainly clean all plastic connector.
Jan 23, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Faded section of screen
Is it an LCD or plasma monitor? If it's an LCD, it's possible that one of the fluorescent backlight tubes is bad. In some early ones, this is bonded to the LCD panel so it's not replaceable. Maybe it's under warranty?
Jul 18, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
