Yahoo! Messenger will not respond. Says check Network Connections. This is fine. Still will not access.
Cannot access Yahoo! messenger. When attempting sign-in box says check network connections. All network connections checked and everything is good. This is the only program I cannot access.
    New Friend:
  • 113 Answers
Check in your Firewall Settings, whether you have given access to Yahoo Messenger or not. Check if Yahoo Messenger been blocked by your system's Firewall.
Posted on Apr 23, 2009
I cant log in in my yahoo messenger i tried to reinstall it and chose from diff version of ym and also trying to use other computer but it still don't work
Is it your network firewall problem? Your network blocks you from accessing Yahoo! Messenger? If it is the reason, you can try to use KarooLark web messenger : http://karoolark.com/
Jun 28, 2011 | Yahoo Messenger
Why computer not respond when I use yahoo messenger
Check your firewall settings on your software to make sure your granting it access.
Nov 04, 2010 | Yahoo Messenger
Cant sign in in yahoo messenger at mozilla fire fox
Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Enable the "Firewall with no proxies" option.
Select the correct Internet connection type and country from the pull-down menus.
Click the OK button at the bottom of the window.
Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the OK button.
Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
Enable the "No network detection" option and then click the OK button at the bottom of the window.
After this steps and this still not solve it. You can check and set your I.S.P and Proxy Server. here are the steps.If neither of the above options work (sorry), you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Enable the "Use proxies" option.
Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the OK button.
If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct
Aug 04, 2010 | Yahoo Messenger
Cannot Log into Yahhoo messenger
1. First, ensure that your computer is connected to the Internet.
2. Confirm that your password is not hacked by loging into your yahoo email account with the same user ID that your using to login to the yahoo messenger, by going to http://mail.yahoo.com.
3. If you are able to log into your email account, your ID is safe.
4. Try to kill yahoo messenger on your system using "Task Manager"
5. To open Task Manager, right click on your computer's task bar at the bottom and click on "Task Manager".
6. Next, click on the "Process" tab in Task Manager, select "YahooMessenger.exe" and click on "End Process" button.
7. If you cannot find "YahooMessenger.exe", then select "Ymsgr_tray.exe" and click on "end process".
8. Now start your yahoo messenger again and try to login. You should be able to login succesfully.
9. If your Internet connection is fine and you have followed the above-mentioned process and still cannot login to yahoo messenger, your system's fire wall is probably obstructing yahoo messenger to access internet.
10. Change the necessary settings on your firewall to leverage access to yahoo messenger.
May 15, 2010 | Yahoo Messenger
I canot log into yahoo msnger
there is some problem in yahoo network connection . you can reinstall the yahoo.
Mar 09, 2010 | Yahoo Messenger
I just came up to download yahoo messenger version 10.0 beta but it wont work out . Ofcourse I do have uninstalled my old yahoo messenger version 8, After several of trials signing in on the yahoo...
well..this problem occurs sometimes with yahoo messenger 10. so you need to know how can you sign in,
when you try to sign in on yahoo messenger 10, please go to messenger settings and then in the connection settings tab, please select your network type, i mean if your network connection is broadband, select broadband..if you are using dial up modem, select it or if you are using lan..select it...then try to login again..
i think your problem has been solved.
thaks for using fixya
Feb 28, 2010 | Yahoo Messenger
I am unable to sign in yahoo messenger. I am using yahoo messenger 9.0 version. After signing in it says problem signing messenger, try again.
1st sorry 4 my poor English.
if you have problem to sigin Yahoo Messenger(YM) . 1st you check the internet explore(IE)is working correctly. most of the time it don't work. (but Firefox,chrome,Gtalk,etc..etc.. are works correctly)
so go to IE ->Tools->Internet options->Connections->LAN Settings-> Check Automatically Detect settings and uncheck other options (See the Screen shot below).
Now IE and YM will work fine....
Sep 16, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Dec 16, 2008 | Yahoo Messenger
Web cam getting network error
goto yahoo messenger -> prefrences - > webcam -> camera source check if it found or not if not reinstall the camera driver hope it willl found and work
Oct 15, 2008 | Yahoo Messenger
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
