Question about Linksys Wireless-G WRT54G Router
Procedure for port mirroring in mtnl switch - Linksys Wireless-G WRT54G Router
  • 3 Answers
Port mirroring is not supported on unmanaged consumer grade switches. You either need a managed ethernet switch or a 10/100 unmanaged hub which will do what you need out of the box.
Posted on Oct 15, 2013
Can't set up Belkin 54g Router with MTNL broadband
Samay,
You should reset your router to clear all information from it. The best procedure to fully clear your device would be to press the reset button with power on for 30 seconds; while continuing to press the reset button, remove power from the unit; and while continuing to press the reset button restore power for 30 seconds.
You should now be able to access the menus after the unit boots up with the default user name/password for the unit. If you do not know them, just Google [your router name] default user name and password. You can now set up the router to meet your requirements. There is a lot of information that will help you on the Internet, but having a clean booted router is important to start with.
Mar 17, 2014 | Gateway Belkin 54g Wireless DSL/Cable...
I want to mirror all traffic to one port in avaya c363t switch. How I can do it?
Not sure on the how on an Avaya switch, but why do you want to do this? This is a really bad idea. Typically you only want to mirror one port to another for troubleshooting purposes such as running wireshark to get a packet capture. Doing all the ports to one will overload the switch.
May 17, 2013 | Avaya 700319932 C363t Stackable Ethernet...
E52 internet pc setting for mtnl
BELOW ARE THE SETTINGS
How to set GPRS settings for your phone (In case Postpaid) Name of Service: mtnl_wap APN: gprsmtnldel IP Address: 172.16.31.10 Port Number: 9201 Homepage: http://172.16.31.23:8181/mtnl/index.wml Username: mtnl Password: mtnl123
How to set GPRS settings for your phone (In case prepaid) Name of Service: mtnl_wap APN: gprsppsdel IP Address: 172.16.31.10 Port Number: 9201 Homepage: http://172.16.31.23:8181/mtnl/index.wml Username: mtnl Password: mtnl123
Dec 15, 2010 | Nokia E52 Smartphone
I have mtnl connection with D-link modem (502T) My connection get disconnected in between download so is there anyway that my modem could restart it self when it looses internet connection.
Signal strength drop or fluctuation are common causes of RF interference.
Try these basic troubleshooting steps:
  • Change the channel on your access point or wireless router.
  • Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
  • 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
  • The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
MTNL GPRS SETTINGS FOR MICROMAX Q3
How to set GPRS settings for your phone (In case prepaid) Name of Service: mtnl_wap APN: gprsppsdel IP Address: 172.16.31.10 Port Number: 9201 Homepage: http://172.16.31.23:8181/mtnl/index.wml Username: mtnl Password: mtnl123 The settings can be obtained from OTA server by either of the following methods :-
a) SMS your hand set Make & Model No to 58354. e.g. SMS 'NOKIA N70' to 58354
b) Call costumer care (1503) to get the settings.
Apr 10, 2010 | Cell Phones
D-Link Service centers in Bangalore - modem problem
Contact Product Support by Phone
Please call 1800 233 0000 (Toll Free - MTNL and BSNL users) and +91-832-28857000 for other users.
9.00 AM to 9.00 PM. All days.
Mar 26, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
Internet problem
Check default gateway and it should be correct.ask your service provider,also try mozilla firefox browse,if problem still persist let me know
Jun 15, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
Linksys Wireless-G WRT54G Router Logo
50 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
