Question about Linksys Wireless-G WRT54G Router
How to do port mirroring in any switch - Linksys Wireless-G WRT54G Router
  • 345 Answers
Every switch has different command set and to try and tell you how to do this for ANY switch would be impossible. If you can narrow it down to an HP Procurve or a Cisco switch, I might be able to help you. If it happens to be an HP. Log into the switch using the i.p. address of the switch in the address bar of your browser. The older style web GUI on an HP switch will have a tab that says "diagnostics" and one of the tabs under that should have page on how to turn on monitoring for a port on that switch. With cisco I would have to know the exact model of switch before I could tell you the proper answer.
Good Luck
Posted on Nov 03, 2013
Can I connect my Tablet to my tv with a USB cable to watch videos or play games?
Only if the tablet supports hdmi out. Usually via the usb port or a dedicated mini hdmi port. Check the owners manual or Google the specs for your tablet. If it doesn't you can mirror your tablet however to do so you either need a wifi enabled tv that supports mirroring or a dongle like roku, chrome cast etc. with mirroring capabilities.
Nov 14, 2016 | Tablets & eReaders
Can aux power ports on my 2007 be turned off when car is not running?
Not if car is factory wired to leave ports on all the time. If the ports are running off a fuse you could pull fuse. Many newer vehicles have at least one port that is always "hot". The only way to change this is by taking port area apart and running new wire that goes to power that is killed by key being turned off. Just remember to tape that hot wire off good (if you do change it) because if it touches something you will blow fuse or burn wire.
Jan 11, 2015 | Chevrolet Trailblazer 2007 Door Mirror...
Procedure for port mirroring in mtnl switch
Port mirroring is not supported on unmanaged consumer grade switches. You either need a managed ethernet switch or a 10/100 unmanaged hub which will do what you need out of the box.
Oct 12, 2013 | Linksys Wireless-G WRT54G Router
I want to mirror all traffic to one port in avaya c363t switch. How I can do it?
Not sure on the how on an Avaya switch, but why do you want to do this? This is a really bad idea. Typically you only want to mirror one port to another for troubleshooting purposes such as running wireshark to get a packet capture. Doing all the ports to one will overload the switch.
May 17, 2013 | Avaya 700319932 C363t Stackable Ethernet...
2007 gmc heated mirror module
Could have a DDS an PDS .depends on what RPO code yours has >
Outside Mirror Description and Operation (with RPO DL3)
Or
Outside Mirror Description and Operation (without RPO DL3)
Without
Heated Outside Rearview Mirror Operation
The REAR DEFOG relay controls the operation of the heated outside rearview mirrors. When rear window defogging is requested, the REAR DEFOG relay is energized and B+ is applied to the supply voltage circuit of the mirror heater element, located in the mirror face. A constant ground is also applied to the mirror face. Current will pass through the mirror heater element, warming the mirror, so long as the rear window defogger is commanded ON.
With
The DDS and PDS control the activation of the mirror heaters. Upon receiving a serial data message indicating a request for heated mirrors, the DDS and PDS, will apply voltage to the mirror heater element supply voltage circuit. The mirror heaters will remain active until a new message is received indicating rear defogger is to be deactivated.
The power mirror system consists of the following components:
• Driver Door Switch (DDS)--An electronic control module with integrated switches and requires programming when replaced
• Passenger Door Switch (PDS)--An electronic control module with integrated switches, requires programming when replaced
• Power Mirror Direction Switch--Integrated into DDS and is a four position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a three position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Mirror Extend/Retract Switch--Integrated into DDS and is a two position switch that allows the operator to select the mirror extend or mirror retract position
• Left Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Right Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Body Control Module--An electronic control module that requires programming when replaced, serves as the power mode master and is the main message handler
• Horizontal and Vertical Position Sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDS/PDS and provide a variable voltage signal to the DDS/PDS that is proportional to mirror position
• Folding Mirror Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Your best bet mite be to take to a qualified repair shop , i really don't think you'll be able to do anything with it.
Do you have wiring diagrams so you know which wires to test ,do you know how to do electrical testing ?
The Driver Door Switch (DDS) and Passenger Door Switch (PDS) supply voltage to the outside rearview mirror heater elements upon receipt of a serial data message from the HVAC module indicating that the rear defrost system is active. The door switch supplies B+ through the driver/passenger mirror heating element supply voltage circuit when a request is seen. Ground is applied through the driver/passenger mirror heating low reference circuit.
Sep 15, 2017 | 2007 GMC Sierra 2500HD
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Apr 06, 2017 | 2003 GMC Yukon XL
Power mirrors don't work. Which fuse controls this
Here is repair information from Mitchells:
1) Disconnect power mirror switch connector. Connect test light between power mirror switch harness connector terminal "A" (orange wire) and ground. If test light illuminates, go to the next step. If test light does not illuminate, repair open in orange wire between power mirror switch and righ rear power distribution center fuse block No. 1 (located under left side of rear seat).
2) Connect test light between power mirror switch harness connector terminals "A" (orange wire) and "J" (Black wire). If test light illuminates, check for poor connections at the power mirror switch. If connections are okay, replace power mirror switch. If test light does not illuminate, repair open in Black wire between power mirror switch and ground.
Aug 04, 2009 | 1997 Oldsmobile Aurora
The purpose of hp procure switch 2626
There is nothing special about these switches other than that they are managed. Managed means they have some means of connecting to them and "managing" them like you do when you configure a wireless router by going to some ip address in your browser to access the configuration. They usually are able to communicate statistics, set up virtual subnetworks, monitor ports, mirror ports, control which ports can access which others, set speed limits on ports, etc... A normal switch is "dumb", there is nothing to configure and it just does it's thing, connecting anybody and everybody that are connected to any of it's ports. Procurve switches are popular because they are great switches, there are other managed ones that can be had for much less, I use 48 port managed Linksys that have/exceed these capabilities for way cheaper... examples
Jan 28, 2009 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Power Mirror Switch
change the wires around on the switches ,practice makes perfect
Nov 15, 2008 | 2000 Volkswagen Beetle
DES-1005 in HUB working mode?
Unfortunately, the DES-1005 can not be configured to behave as hub and send all the packets to your analyzer software.
Do you have a manageable switch available. Most manageable switches have a "port mirroring" or "monitor" function that allows you to copy all the traffic passing through one port to another port...where the wireshark can receive it for analysis.
Jan 20, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Linksys Wireless-G WRT54G Router Logo
42 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
