Question about Dishwashers
How do I stop my Siemens IQ100 dishwasher when I have put it on the wrong cycle?
2 Suggested Answers
SOURCE: siemens dishwasher sl33a002uc takes 4
Take the control board out, open it up, and resolder the heater relay or replace the control. It may be under the recall and you can get a new control replaced for free.
Posted on May 18, 2011
My siemens dishwasher wash cycle keeps going. It should be done after 2 hours but the timer count either stops working or moves much slower than the allotted time. Ideas how to fix it?
You cannot fix it since you may not have the knowledge to do so. Maybe all that is needed is a new timer, but only a trained tech can determine that.
Feb 23, 2015 | Siemens Dishwashers
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
I set the dishwasher Siemens SL84A to regular wash cycle . I hear it click like its going to start, warm water fills the bottom up the tub but it never kicks into the wash cycle. Hit the cancel cycle and...
Most likely issue here is that the door is not sealing properly or the sensor on the door is not working, so it can fill up much as your washing machine does but just as the washer won't spin without the door closed neither will the dish washer. An easy way to check this is to let it fill and then lean or push against the door some and see if it starts, if so then the issue is the isn't sealing properly.
Dec 04, 2013 | Siemens 24 in. SL84A305UC Built-in...
Error E09 on Siemens dishwasher
There is nothing you can do yourself so contact an authorised repairer. There is a fault in one of the sensors.
Feb 09, 2013 | Dishwashers
My siemens dishwasher model SL34A002UC/22, does not go to the dry cycle. It keeps washing and stays on the last minute and doesn't stop. Could it be the control board?
it is probably the timer , if u open it and pull off the plastic lining inside you can get at it just unplugs pay attention to the little peices and springs so u can put it back together ...
Apr 08, 2011 | Siemens Dishwashers
Siemens dishwasher sl33a002uc takes 4 to 5 hours to complete a cycle - what is wrong?
Feb 07, 2011 | Siemens 24 in. SL34A006UC Built-in...
KU15RA50GB - iQ100 Built-in fridge stopped working the back of the fridge defrosted, i moved the unit where the light and temp dial are situated and the fridge started to work again for aprox 24 hrs then...
if the frig keeps frosting then it must have a defrost problem as the nofrost ref do not have frost . i thim=nk that moving the frig is only looking like it changes things but the problem still is in the no frost system .. mm
Sep 01, 2010 | Siemens Refrigerators
Dishwashers Logo
Top Dishwashers Experts
