Question about Hardware & Accessories
How to wire a grasslin pool timer - Hardware & Accessories
  • 5,245 Answers
Add a comment and describe the timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Gene
h
Posted on Oct 12, 2013
Grasslin Intermatic pool timer turns on and off randomly
did you change the base out or just the clock?? it could be shorting out threw the base
May 29, 2014 | Intermatic Grasslin Pool Time Clock 24hr...
Grasslin ecosave timer not working
Add a comment and say if the timer worked before and stopped working, or if this is new installation that does not work correctly.
Otherwise the timer expert is guess that the problem is incorrect wiring, defective timer, tripped circuit breaker, or if the clock motor has gotten weak over time, and stopped working.
Or, Contact Grasslin UK:
http://www.grasslin-controls.co.uk/ecosave.html
Aug 25, 2012 | Hardware & Accessories
How to set my grasslin pool time trying to understand to let it run in day and shut off at nite about 6pm so i need to set it that way with the pin
Open following link for setting Intermatic/Grasslin FM1 timer setting instructions:
To set the 24-hour analog timer, you need to move 4 consecutive tripper pins for each hour of run time.
So for 6 am to 6 pm, 48 trippers pins will be moved outward and 48 inward.
http://waterheatertimer.org/pdf/How-to-set-Intermatic-FM1-timers.pdf
Open following link for Intermatic FM1 series and PB series modular timers with wiring, manuals, model numbers and instructions for setting.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
Grasslin timer instructions
Grasslin timers and manuals
Click timer-categories on left to see drop-down menus
http://www.intermatic.com/products/grasslin.aspx
Grasslin electronic time switch
Click on model number and drop-down menu shows manuals
http://www.intermatic.com/products/grasslin/electronic%20time%20controls/electronic%20time%20switches.aspx
Oct 11, 2010 | V, Inc. 12v Dc Timergeneratortransfer...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Wired incorrectly need wiring diagram
I have baxi combi boiler genesis 80 and grasslin timer need to no what wires go were there are 4 wires coming out the timer red and brown together white and blue the timer is internal one can you help
Mar 18, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Hardware & Accessories Logo
53 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
