i have a harness that fits but it's for a panasonic or pioneer or sumthing and i guess the colors are diffrent.. i looked at the manual and it shows wires but theres two rows of wires and it only shows one. ive tired all day to make it work but i can't seem to. hope the things not broke and im not wasting my time.
Okay there are 2 possible solutions depending on your problem
Number 1 If its the lead that plugs into the back of the headunit then this is the page you need Click Here All you have to do is choose the one you need! just look at how many pins there are pretty simple to work out
Number 2 If its the lead that plugs in from your car loom to the headunit loom then you need to look here and pick out your car
I'm not completely sure of what the problem is. Normally, when you purchase a receiver, you get a wiring harness with it. That harness is meant to be plugged into the receiver and connected into the vehicle wiring according to the diagram in your manual.
You also need the color codes of the wiring coming from your vehicle's original radio harness. And unless, you are willing to cut or tap into the vehicle wiring, it's best to purchase an aftermarket harness specific to your vehicle. These are made by Metra, Scosche, and others, and are well worth the $10-15 they cost. You simply plug it into the original vehicle wiring and match up the function of each wire according to your Kenwood manual. You can find a harness for most every make and model of vehicle here: http://www.sonicelectronix.com/cat_i95_wiring-harnesses.html. SonicElectronix also has replacement harnesses for many aftermarket receivers, including the Kenwood.
Hope this helps. If it does, please rate as "FixYa".
There is no sound from the speakers but the system is playing CD's. As I reset it and higher the...
(More)
There is no sound from the speakers but the system is playing CD's. As I reset it and higher the volume, the display 'CALL' appears. The radio or the CD can not output sound to the speakers. May be you can help me out.
i just bought the unit. it was working for the first two days. the third day it keeps scanning the...
(More)
I JUST BOUGHT THE UNIT. IT WAS WORKING FOR THE FIRST TWO DAYS. THE THIRD DAY IT KEEPS SCANNING THE RADIO FREQUENCIES WITHOUT STOPPING. WHEN I INSERTED THE CD IT SHOWS 'E-04'. HOW DO I RESTORE THE SYSTEM TO NORMAL?
I found the manual online and it was100% unhelpful. The first step is to "Select Clock...
(More)
I found the manual online and it was100% unhelpful. The first step is to "Select Clock Adjustment mode," but it doesn't explain where that is or how to get there. Can anyone help?
I have KDC-MP225 and I Want to calibrate my tuner so it wont skip station - (he dose like 1 3 5 and...
(More)
I have KDC-MP225 and I Want to calibrate my tuner so it wont skip station - (he dose like 1 3 5 and not 12345), i was told once to hold SRC key while the tuner is OFF and then to press two buttons so i can turn it ON whit this settings, but i cant remember how. Thanks,
