Question about Sony Audio Players & Recorders
Hcd vx88 can not hear sound untill unless i press the system from outside from
I have this sony hcd vx-88 hifi system, the problem i an facing is un till unless i press the system it does does not produce any sound, although equilizer showa that song is being played on CD/ MD but still i have to press the system with my hand. ( when ever i press it i hear a sound , kind of a cut out and that it works fine but i have to keep my hand placed over or on the sides of the system. please help................
  • 5 Answers
SOURCE: Sound cuts off
he's partially right... I have fixed 3 shorts on my de845. 2 have been caused by cracked solder joints. they were speaker cutout problems...yours most likely is the center channel relay on the main board. take the thing apart. you need to get to the back of the main board and re-flo those solder joints. get your geeky pc buddy and do it together(buy him a sixer). its really not that hard...just a bunch of screws. disconnect everything from the main board including the front plate. be careful with the ribbon cable...mine is hurting at this point. not meant to be removed so many times. put it in straight. my leads bent, but was able to straighten them. there are 5 relays together, one for each channel. they are white cubes and prb a little smaller than the tip of your finger. its the 4 leads on each of these that you want to take a soldering iron to . i'm not sure which ones the center channel so do them all in that area. it may be hard for you to tell which leads they are so just go overboard and at least get everything in the vacinity. i did all component leads because who's to say another's not ready to go bad. you've gone this far. touch the heated up tip to all the leads at the very end of the barb. you can reflow the solder without actually touching it. the metal lead will get hot enough. hold it until the solder liquifies, then let it cool. do this on a flat surface. my other fix once was a re-seating at the speaker switch a,b,a+b on the front plate. there are 2 boards plugged together there. i bent the leads slightly so they seated in more tightly. if your left or right front goes out, sometimes thats an easy fix...try b if you're using a, or the opposite. don't forget the speaker cables. if you're using both zones then you prb already figured out you need to re-flo! test and cross your fingers. good luck.
Posted on Jul 27, 2007
  • 4234 Answers
SOURCE: WHEN I ON MY HI
There is a problem with the output section. When you turn up the volume, the protection circuit kicks in and shuts down the system. This unit requires service. Expect a parts cost of about $10-$30. Add in the local labor rate for the total repair cost.
Dan
Posted on May 21, 2008
SOURCE: push power protect comes on
The audio amplifier IC are damaged you need to replace him
Posted on Aug 20, 2008
SOURCE: My Onkyo tx sr502 quit producing sound?
I have the same problem.It's definitely the pre-amplifier board (board with speaker terminals).I did not quite nail the exact component yet but I replaced with a working one and got back sound output.
Posted on Apr 11, 2009
  • 7 Answers
SOURCE: 5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Posted on Dec 12, 2009
Sony hifi no sound
DAC [Digital to Analog Converter] problem. That's its main board problem. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 01, 2016 | Sony Audio Players & Recorders
CAN THE DISPLAY UNIT OF MUSIC SYSTEM MODEL HCD VX 55 BE REPAIRED
check the five and twelve volts d.c is reaching the panel and if not trace the fault mostly from a protection zener diode
Jan 29, 2015 | Audio Players & Recorders
Hcd vx88
You should change the Power Amplifier Output IC Named STK-412-150 and that should bring back your component alive, check speakers impedance before, hope this helps.
Nov 07, 2013 | Audio Players & Recorders
Sony hcd-vx88
IC501 it's a Power Output IC Part Number STK-412-150.
Oct 21, 2013 | Audio Players & Recorders
Sony hcd-gx470 manual
My Sony Mini MHC-GX470 have been working until a power outage yesterday and now it will start coming on the goes back to standby mode. I can hear it going through the system, starts the radio and immediately goes to STANDBY.
I need HELP!!!!!!!!!!!!!!!!!!!!!!!!
Jan 07, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Sony midi Hifi switching itself off
These digital amps are very prone to blow if the speaker wires are shorted so Sony appear to have put in a protection system that mutes the amp when this happens. You have to unplug the amp for a minute till the light goes off, make sure no speaker wires are touching each other and then it should work ok. I found the same problem with one I bought 2nd hand.
Feb 03, 2010 | Sony Audio Players & Recorders
WHEN I ON MY HI FI SYSTEM THERE IS NO SOUND COMING OUT OF THE SPRAKERS, AND WHEN I INCRESE THE THE VOLUME TO 16 OR ABOVE THE HIFI SYSTEM AUTIMATICALLY TURNS OFF. TO RE START THE SYSTEM YOU HAVE TO TURN IT...
Dan
May 21, 2008 | Audio Players & Recorders
48 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
