Alright, what's happening is that when i hit the power, the LED lights up, the fan turns on...but the screen never shows anything. i've tried unplugging everything, removing the battery and holding the power in for 30 seconds, and no dice. after looking far and wide for answers regarding my problem and seeing that most solutions regarded getting the motherboard fixed, i got inside and checked it...no problems there. what's going on?
    Novelist:
  • 166 Answers
Heyyy.... i am sure its not just about motherboard... its about RAM only... you replace your RAM with another one and surely it will turn on... and also RAM is not so costly but Motherboard will cost you so much money !!!
Posted on Apr 23, 2009
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
Have an asrock 939sata2 I hit the power to turn on the led lights up along with the floppy drive light all the fans come on but that's it nothing else any solution?All the fan motors come on but t
Power Supply with a weak voltage power rail.
[There are 3 voltage power rails. 3.3 Volts, 5 Volts, and 12 Volts. All are DC Voltage ]
Enough power to light LED's, and spin fans, but not enough power to turn the Processor on.
1) If ALL of the LED lights were on at once they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it is.
Suggest you check the three main voltages with a multimeter.
Since the Soft Power On circuit uses 5 Volts, I have a feeling the 5 Volt power rail may be the bad one.
An economical multimeter can be purchased for as little as $5 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Need guidance in using it just post in a Comment.
Or you can borrow a KNOWN to be good, Compatible power supply, and use it for a test unit.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Sony ASROCK 939Dual-SATA2 / 939DUAL SATA2...
My toshiba satellite c655d-s5080 wont come on even though the power light comes on and the fan comes on after a while
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 11, 2012 | Toshiba Satellite C655D-S5080 Laptop
Aspire 5110
So does it sound like your laptop is running and booted up all the way except the screen is blank? if so try the steps below:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 08, 2012 | Computers & Internet
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
I have a sony VGN-TX670P the problem is when I try to turn on the power led turn on but doesn't show anything on the screen, turn the bluetooth and wireless led on, but don't do anything. I conect an...
It may be a BIOS or Motherboard proble !
* Can you hear the sound of the cooling fan...it's working or not ?
* Does the BIOS appear when you turn ON the system ?
Jan 08, 2010 | Computers & Internet
Toshiba wont power on
try turning off and then remove battery and plug in a/c cord.turn back on..still nothing let me knowRICHARDM69
Aug 24, 2009 | Toshiba Satellite A135 Notebook
Power light is green but screen is black
Do you get anything at all on the screen--like white writing at startup?
Even if your video drivers have become corrupt, they are not used until Windows actually starts.
It very well could be the flourescent backlight has gone bad. Can you adjust the brightness/contrast at all to see anything?
If those controls do nothing for you, then you're looking to get a new monitor.
Your monitor does have a sort of power supply for the backlight and that could be bad, but if you're not into taking it apart, then you are far better off buying a new monitor.
May 27, 2009 | Philips Computers & Internet
Acer aspire 4330 will not boot up
Can you plug a external monitor into the machine, most laptops have that serial port. If montor comes on, you have bad display or connections, If not you have problems with laptop....Good luck
Apr 23, 2009 | Acer Computers & Internet
No booting anymore
Sound like a motherboard problem.
If you unplug and remove the battery, the light should turn off
put the ac back in, power up, do fans spin? any beeps? just the light?
Jul 06, 2008 | HP Compaq nx6310 Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
