Question about Moen Posi-Temp Single HandleTub And Shower Faucet
I have a Moen Posi-temp single handle tear drop tub and shower that gives me no hot water
    New Friend:
  • 92 Answers
I am assuming you have hot water in same bathroom and that its fed by the same pipe? if so ask yourself did i have anything done recently that may have affected the shower ?if not i would think you have some kind of a blockage in fitting. one way to try to clear it is shut off water to house open shower fitting to what used to be the hot side when working,leave shower open,go o lowest level of house open hot side in sink you may get lucky and vacumn(think ****)debri from shower good luck .
Posted on Apr 24, 2009
MY Moen single handle shower knob turns in a complete circle. From left clockwise, it goes from hot, tepid, cold, tepid, then back to left-hot. What causes this and how can it be repaired?
It sound like you have a Moen Posi-temp faucet and the handle is broken. It is probably an acrylic hdle with a tear drop shaped cover. Take a knife and slide it under the cover to pry it off. Unscrew the center screw and the handle will pull right off. You will see two shoulders inside the hdle, one of which will be cracked and broken. Replace the hndle which can be purchased at any Lowes or Home Depot. Plumbing supplies also carry replacements, but you can probably get one cheaper at HD or Lowes.. Make sure to use the washer provided. It has two flats on the inside of washer. Slide this over the brass stem on your cartridge, NOT on the hdle screw. Install it with the flats of the cartridge in horiz. position. Try faucet. If the water comes out in the opposite temp you expect, warm is cold, and cold is warm, remove the hdle, spin the stem 180 degrees and reinstall hdle.Good luck!
Oct 22, 2013 | Moen & Posi-Temp Single Handle Shower Or...
My single moen posi temp shower knob wil not completely turn off my water. In the closed position it still runs a slow stream of water.
Remove the handle and see if it will turn off without the handle and if it will reposition the handle alignment and your good to go. If no the cartridge will need to be replaced.
Feb 12, 2011 | Moen & Posi-Temp Single Handle Shower Or...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Temp control doesn't allow water to get hot enough
remove the handle and there should be a white plastic deal behind the handle that you can remove it's a temperature limit setter so people dont burn themselves remove it and you will get the full hot water
Aug 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
366 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
