Create Menu tab right click
in the top of screen (toolbar) you will see a number of toolbar options select
the menu bar
This will add to your
screen toolbar File Edit View Favorites Tools and Help
select the View from the drop down list will be a Zoom with percentages % and
text sizes largest to smallest and Full screen option Increase the Font Size in Email
Email font size is easily controlled while composing
messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size
8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text
are even more difficult to read.
There are a few ways to quickly change font size for ease of
reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font
size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100
percent.
Click "View" and cover "Zoom" to make a
larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll
the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is
"Medium," then click "Larger" or "Largest" to
make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the
wheel on the mouse.
The text will shrink as you roll in one direction, and grow
bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display
"100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text
size.
Click the "Print" button to view the
results on a hard copy.
to increase the font size in the printing cheque is just simple go on to (or) press F!! key on the cheque printing option will available on there on the give yes . and then some kind of list will available on there on the list read the sentence one by one the font increasing size is available on there give the correct font size as a number for example (60)
Go to to print menu box i.e. press ctrl P. Look for zoom. There you will see "scale to paper size." Here select from the drop down list "no scaling" or "A4" depending your paper size. This shoule correct it.
In case you do not see these on your print menu click "properties" on your printer. In the box that appears look for "scale" and make it 100%. These are the components that control percentage size of original documents printed.
Set the font number on your favorite text editing program to something legible, for example, in Word, a size from 5 to 10 is normal letter.
If letter stills going little on printer, then take it for repair.
first I need to know what internet explorer your using.....may I
suggest downloading IE 7, Its an upgraded IE, and down in the lower
right hand corner, you can easily change the font, or print size....go
to www.microsoft.com If this helps please rate me, and thank you
The font size is going to be controlled by the program you are using. For normal word processing you would use a 10 or 12 point font.
If you are referring to printing from a browser like Internet Explorer, you can change the font from the Internet Explorer menu VIEW > TEXT SIZE > MEDIUM (normal).
Note: Internet Explorer font settings effect Outlook Express too.
I have a solution for the issue which you are experiencing with.
As we do not have much information regarding the application from which you are trying to print, I suggest you to increase the font size while printing.
I believe, that you are experiencing the issue with Internet Explorer. If it is, so, please open an Internet Explorer window and click on View-->Text Size and select Medium which would resolve the issue.
