Question about Pioneer ADF1031
Hi I have a PDP434HDE TV. I am moving house and can't get the old 10m Duel DVI Cable from under the floorboards. Does anybody know if there is a workaround to this perhaps connecting another cable or where I can get hold of another 10m cable? I think the cable that will work with this is ADF1031. This cable apparently works with several Pioneer TVs. Regards, Trevor...
    New Friend:
    Problem Solver:
  • 10 Answers
You can ask some custom cable company to make one for you, try to find your desired product here or email to its engineers to give you some help.
Hi I have a PDP434HDE TV. I am moving house and - 912bfd8c-8f3e-4f18-b01a-09425bf2e4ba.jpg
Posted on Nov 12, 2013
4 Suggested Answers
SOURCE: Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Posted on Jun 28, 2008
SOURCE: Pioneer Pro-97 Cable Problem
WILL NOT SHOW A PICTURE
Posted on Dec 23, 2008
  • 375 Answers
SOURCE: I want to connect my
depending on the connections available on your pc, you can get a vga to rgb cable fairly cheap but I am not sure on how good the quality will be, same with the s-video connection. vga connections on the pc are usually blue in colour, if you have dvi connection you can get a similar cable to do the job. Most computers will auto sense the tv if you connect the cables with the pc switched off, make sure you are on the right channel on the tv and the switch on the pc.
hope this helps
Posted on May 06, 2011
I can't get either of my 2 computer monitors to work through my DVI D cable, both monitors work through a VGA cable, just the DVI wont work, what is wrong?
dvi cable most likely will only work as a second monitor rather than as a primary monitor. Suggest checking you computer video card specifications to see if this is the case.
Apr 23, 2018 | Vga Computers & Internet
How to connect the HDMI Cable from monitor to Computer which has no HDMI ports?
You need a purchase a new cable. I assume your HP pavilion is under 5 years old. And you should have a white DVI port in the back for a monitor. If you do have that connector, then all you need is a DVI - HDMI cable, make sure the DVI will be to the computers end and HDMI to the monitor.
for example this cable:
http://www.amazon.com/AmazonBasics-HDMI-Adapter-Cable-Meters/dp/B001TH7T2U
Dec 31, 2013 | HP Pavilion Computers & Internet
NEC PXT42SPKR
sadly we have no idea if it was 110 or 220 . try searching thru Google
Sep 11, 2017 | Televison & Video
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
I use attached the pc on tv but i didi not here any sound please tell me sound pin cable attached the tv?
Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
Mar 22, 2011 | Samsung HLP6163W 61" Rear Projection...
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I have an acer aspire 5315 what cables do i need to run video from my laptop to tv
in depends on what available ports are on your system and tv. it may be a HDMI cable, or DVI. check this: http://www.cablestogo.com/resources/AV.asp
Mar 31, 2010 | Acer Aspire 5315 Notebook
LG32LZ55 TV GOING INTO DPM MODE
Hi Ben,
Did you ever resolve? I have the same issue.
Jun 18, 2009 | LG Televison & Video
This TV won't support 1080!
Low or poor signal from the cable company. Try another signal source such as a DVD play.
May 12, 2007 | Hyundai Q320 32 in. LCD Television
Pioneer ADF1031 Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
