Prima LPR730 Do you know what error code F7 means
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Hi Sue this may be the problem. Found it on the net.
F7 error fault code
This is flow meter failure. The flow meter impulse wheel (situated in the water tank) is not turning correctly, too fast or too slow therefore the electronic impulses received by the module/pcb are not correct, also the water valve can be faulty.
Hope it helps.
Steve
Posted on Oct 12, 2013
Good afternoon, My Brother sewing mach. has a error of f7 what does this mean. The model is Cs80
According to http://www.sewingmachinesplus.com/brother-sewing-machine-error-code-f7.php
the meaning and answers are as follows...
Q: What does F7 error message mean?
A: Speed VR disconnected
Q: How to fix F7 error message?
A: Unplug the sewing machine and reconnect any loose wires on the SSVR PCB assembly and the main PCB assembly. If the wiring connections are okay, replace the SSVR PCB assembly. If the problem persists, replace the main PCB assembly.
Jan 10, 2017 | Brother Sewing Machines
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
F7 error code on GE gas oven model # JGBP90MEA2BC
On this model, code F7 means there is a keypad malfunction, and therefore the range's "computer" isn't getting a valid signal from the keypad. It may be a stuck "touch-key", a bad connection between keypad membrane and the range/computer connector, or more probably a faulty keypad membrane.
In some cases it can be a defective computer module. You can test whether the problem is the keypad or computer unit by disconnecting the keypad entirely. If an error code F7 still shows, then the computer is faulty.
If this was helpful, please rate via the helpful button.
Nov 04, 2014 | Kitchen Ranges
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
About 1 hour into the self cleaning process the F7 error light came on and I meed to know how to get rid of it?
on maytag's the F7 means a function key is stuck or shorted. google your oven model's codes.
Jun 22, 2010 | Ovens
GE oven JS900
I figure you me f7 and f8 here is what the coad means. there is no d8 code.
F7 This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced. F8 This code usually means that the electronic control needs to be replaced.
Good Luck and Please Rate FixYa!
Dec 19, 2008 | Magic Chef CGS3760 Gas Kitchen Range
My whirlpool dishwasher is showing a F7 error code what does this mean ?
f7 error codes on whirlpool normally mean you have a bad control board..
May 08, 2008 | Dishwashers
Whirlpool dishwasher ADP5962 F7 error code
emmanuelr is spot on with this advice. The dishwasherr had been idle for a few months so as advised disconnected and reconnected the connection to the water flow meter and job done. My friend you are a scholar and a gentleman thank you so much. You are not an apprentice to me.
Dec 03, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
