Question about Thetford Porta Potti
Thetford cassette c402. Valve blade has gone(somewhere) need to find/replace it
3 Suggested Answers
  • 7 Answers
SOURCE: We need a Manual for a Thetford Cassette C200,
Email Thetford Australia on infoau@thetford.nl and they will email a copy of the manual.
Posted on Oct 13, 2011
  • 7 Answers
SOURCE: I need to replace a fuse on my thetford c402
Remove the cassette and look on the side walls, you should see a square box inset flush in the wall. This is just clipped into position and will pull out, the fuse is on here.
I need to replace a fuse on my thetford c402 cassettee. How do I get to it
Oct 12, 2011 | Thetford Porta Potti
Where is the water pump on a Thetford C 402 C/X located and how do I get to it.......thankyou.....Mal Hughes Western Australia
hi the water from the flush holding tank is not getting through to the pump on my c402 thetford toilet . i have tried putting water in from the glass indicator tube and the the flush works . anyone got any idea what the problem might be thanks
Oct 12, 2010 | Thetford Porta Potti
We have a thetford C200cs on the motorhome we have just bought (2003). No water seems to pump, & the blue flush button doesn't seem to work. Are there any instructions availabe? The fuse has been...
Red light is just a reed switch that turns on the LED when a floating magnet inside the cassette floats up (when the cassette is full) and switches on the reed switch thereby switching on the LED. It just tells you the cassette is full and you need to empty it.
I'd say either your button or electric valve is broken. All the button does is allow the electric valve to break the seal that allows water to flow from your onboard water system.
I'll assume that the water in the rest of your motorhome is working?
So check the switch first.
You can lever off the switch/LED panel and remove the square connector from the back of the button. Get a multimeter and set it to either Continuity or Resistance (Ohms). Place the connectors on 2 of the switch pins and press the switch (the switch is actually 2 switches with 4 pins, but each pair of pins is connected together) - if you get a beep (if multimeter on continuity) or low resistance reading (if on resistance) then the switch is working - if this is the case then it's probably the electric valve. If the switch is not working, then that's your culprit.
When you replace the connecter you can replace it either way round.
Feb 01, 2010 | Thetford Porta Potti
Electric diagram c2
go to thetford main site, you can download all manuals and diagrams
Jul 02, 2009 | Thetford Porta Potti
Flushing knob on a C2 Theford cassette porta potti hard to turn
Hi! Spray blade which closes holding tank with silicone spray. Make sure spray goes under lip of sealing ring. Also spray around holding tank actuator knob allowing to penetrate underneath to shaft. Don't use a silicone grease as this will gum up the works. If you can't get hold of a light silicone spray try using household type silicone polish intended for furniture. Wipe off any surplus as only thin film required.
John Long
Jun 07, 2009 | Thetford Porta Potti
Casset toilet will not pump water for flush
Open door, remove toilet cassette unit, look in under flush water tank, observe a short metal blade that actuates a safety switch. This is between two plastic guides. Now look just outside the right hand guide. There you will find the fuse which is a standard blade type. Just pull it down to remove from holder. You will probably find it rated at 3 amp. If it is blown you will probably have to replace pump. Looks difficult but is actually dead easy. Instructions come with replacement Thetford pump. Only problem you may have is a perished sealing ring on the paper holder cup which is no longer available as a spare. Just use a good quality outdoor type sealant as a replacement. Be sure to recover any bits of broken ring from the flush water tank as these can be drawn into your replacement pump and cause it to sieze. At minimum this will cause you to say bother! Happy repairing.
May 27, 2009 | Thetford Porta Potti
When I flush, no water comes out?
Happy repairing.
May 21, 2009 | Thetford Porta Potti
Need take out thetford toilet of ace award
can anyone tell me where is the fuse fits under a thet ford cassette toilet model ppc2r and wot size
Apr 27, 2009 | Maximum Thetford Porta Potti 365 Portable...
Thetford Porta Potti  Logo
75 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
