Question about Toys
How to diagnose atm faulty panel control board
Error code 21 Direct current DC peak error / internal power module IPM fault; compressor DC voltage was too high.
Normally this is a faulty controller or driver control board in the outdoor unit. The compressor can also be faulty but you will need a tech to diagnose.
Sep 08, 2015 | LG LS307HV3 WaAir Conditioner 30,000 BTU,...
What is control board assemble and how can I see it?
The control board is on the front panel and you will need to remove the front panel to get access.
Please check this link Control panel How to Diagnose Washing Machine Control and Program Problems
May 04, 2015 | Washing Machines
One of my Fujitsu indoor units will run on high speed,is board the problem?
Most likely a faulty indoor controller board but also possibly a faulty fan motor. Call a tech to diagnose.
Feb 16, 2015 | Fujitsu Heating & Cooling
Vertical lines
You will most likely need to have the set diagnosed. Vertical lines can be the result of a defective t-con board, faulty lcd panel/t-con connections, or a faulty panel itself. Do the lines stay or do they come and go? Older Samsung sets are known for faulty LCD panels!
Oct 20, 2013 | Samsung LN46B640 LCD TV
No control panel lites. Washer started then stopped as if power shut off.
Hello John - Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn on the unit. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Jul 03, 2013 | Frigidaire Dishwashers
My sumsung LCD tv series 4 cannot see the image....somebody help me please
The set will need to be properly diagnosed. There are a number of things that could cause your problem. You could have a defective CCFL backlight, defective inverter board, power supply problem (particularly with the 12v or 24v circuits), faulty main board, or a faulty T-con board. So getting a correct diagnoses will save you time and money. It will also help you make the decision whether or not the repair is worth it.
Sep 03, 2012 | Televison & Video
Speed control board
Either the timer or control board are faulty - contact a professional to have it completely diagnosed accurately and repaired.
Aug 08, 2012 | Frigidaire GLTF2940ES Front Load Washer
Philips 32pf9641d/10 fault works well for 90 mins then goes black still images on screen but no backlight ? power supply or inverters? if inverters can they be repaired or replacement only,
Hi.
As you said when there is no backlight the problem is either inverter or power board. In some case the main controller board may be responsible.
You need to test the parts to find out what part is responsible. Testing is done tracking voltage from PSU to inverter. Voltage to inverter is usually supplied by the higher VDC line from PSU. Here broad description of how to test the three parts: Before proceeding...
The TV can be repaired at component level or replacing boards, depending on your skills and experience. If you want to repair at component level, after diagnosing the faulty board you test components and circuits individually. In that case to test inverter in full you will need an oscilloscope to read the phase of inverter AC section (oscillators or IC must be tested).
Note: If Inverter has voltage out to CCF lamps, then the parts mentioned above are OK, in that case you have a faulty LCD panel. The TV is usually not worth repair as the LCD panel is expensive. LCD panel faults are not common.
Here replacement parts for most flat panel TV models:ShopJimmy.
See also:
PartStore
Regards.
Ginko.
Sep 20, 2011 | Televison & Video
HRATER WILL NOT COME ON shows a code 5F
the Code 5F is a Temperature sensor failure. The temperature sensor may be defective or the controller board may be defective. If you have an ohm meter the best way to diagnose if the sensor is faulty is to contact Hayward technical support and they can help you diagnose it. If the sensor is ok then the controller board is defective.
Aug 06, 2011 | Hayward H-series Electronic Gas Pool...
When I push the start button, nothing happens.
You could very possibly have a faulty control board. But to properly diagnose that this is the problem, you will want to get an ohmmeter to test the wires going to and from the control panel. You may also want to use a voltmeter and test power to the motor and also from the main power supply to the main board. There should be power. Let me know how it goes and what you think.
Nov 15, 2009 | Danby DCD5505W Electric Dryer
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
