Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Washer drum does not turn - Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
  • 28 Answers
Major problem, could be transmission or timer switch cost for repair could be high
Posted on Oct 12, 2013
Drum is not turning
Dyson Flowcheck CRO1 Front Load Washer "drum seized ...
www.fixya.com > ... > Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer, drum seized related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Memory CRO1 Front Load Washer
My washer will not spin and acts like the inner drum with holes is stuck, what is wrong?
One of two reasons: The drum belt has broken and needs replacement, or TWO, check for an object that may have accidently jammed the drum from turning; such as a sock falling into the tract where the drum rotates, or a bad seal. Check the drum for movement by hand, and see if you can free it up manually. Last: check alignment. Look for damaged fittings.
Feb 04, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My 5 year old washer makes a squeaking sound
If the washer is making a loud noise while the drum turns, the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer should it be the bearing. This work will need a technically minded person to accomplish.
Jul 04, 2014 | LG WM0642H Front Load
My front load washer is making a loud noise and think it is the motor, i took the front bottom panel off and the sound was coming from the what looks like motor i guess not sure what to do
Remove the rear panel . remove belt . turn drum pully if you hear any noise it is the rear drum bearing and seal . Reach inside drum from front and lift up on inner drum. If this drum moves up and down or side to side you will also need to replace the inner drum. If turning the drum is silent try turning the motor if it makes a noise replace the motor
Oct 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Drum is stuck and does not move after a noiny spin. pls advice.thanks
Sounds like possibly the main drum bearings have seized.
To check, remove the rear panel of washer, remove the drum belt, and try to turn the drum by hand, if it is noisy or rumbling, or not turning at all, then likely the the drum bearings have seized.
This is a major repair, and could be expensive!!!
Mar 17, 2010 | Indesit W 123 Front Load Washer
What does the lr code mean
The code means locked rotor. Disconnect power to the washer and remove the rear access panel. Remove the rear access panel securing screws and pull the panel off the cabinet.
Turn the drum pulley by hand to determine if there's a restriction that caused the locked rotor error. If there's a restriction, remove the drive belt. Pull the belt from one side of the drum pulley then turn the pulley in such a way that the belt unwraps from it.
Turn the drum pulley and the motor pulley to determine whether the drum or the rotor is being restricted.
The outer tub bearing is damaged if there's restriction in the drum pulley. Specify the model of your washer for the specific replacement part/s and installation guide.
Try to free the rotor if it is stuck by forcibly turning it back and forth. Replace the drive motor if the rotor cannot be unstuck. Specify the model of your washer for the specific replacement part and installation guide.
Mar 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum will not turn
check the belt if its not that the the brushes need replaced in the motor that will fix the spin problem
Mar 03, 2008 | Indesit W 123 Front Load Washer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
