Question about Sharper Image Office Equipment & Supplies
Where is the internal fuse in my projector?? - Sharper Image Office Equipment & Supplies
  • 20,706 Answers
Inside, be sure to unplug it ,before the take down.
Posted on Oct 12, 2013
Dell DLP projector won't turn on. Does anyone know a fix?
have you changed the lamp recently, or cleaned the air filter.
The internal fuse may be blown, or a whole lot of other things may be wrong, so we need more information otherwise it's off to a technicain to check it out.
Mar 17, 2011 | Dell 1100MP DLP Projector Multimedia...
NO power, no lights, possibly there was a flash before it went of
The internal fuse is normally located very near the power plug socket and usually a Buss glass fuse, rated 5 amps? If you get to it, check the metal end for the rating.You have to remove the top cover to get at it...remember, the problem could be the fuse--or the power supply section has failed.--Rick
Feb 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Marantz vp4001 is completely dead??
warning indicator led lit up means something dis connectivity inside the projector
1)lamp cover switch or its connection from main board
2)fan connectors
3)thermistor connector
above casues for machine shows warnnig temprature indicater
and projector remains in standby mode
Jan 05, 2009 | Marantz VP4001 DLP Projector
Projector has no power
Please check out fixmyprojector.com
this unit most likely has internal issues that are not designed for consumers to fix.
Dec 11, 2008 | InFocus IN24 Multimedia Projector
Projector not working
Have you tried the internal fuse? without a proper fuse in the panel you will get no power i.e. lights and such to the device. Simple but the first place to check.
Nov 02, 2008 | InFocus LP350 Multimedia Projector
Help
Hi there
The internal fuse will be located on the Main Powersupply Board ( the one that takes in the AC socket )
Sep 11, 2008 | Office Equipment & Supplies
Power (maybe internal fuse)
This sounds like either the power supply&Ballast is blown. Or the lamp blew out. Take the lamp out, look at the bulb to see if it is frasted heavily or just broken. If not you might want to send it in for repairs.
Aug 13, 2008 | Office Equipment & Supplies
No power lights
ok " could be a internal fuse, or bad transformer
Id check for a fuse first
Nov 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
Hitachi Performa CP-RS55 Multimedia... Problem
ok " sounds like you have a short, thats why it's blowing fuses
Nov 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
Internal fuse
HI
Check that you use another power outlet,see that the power cord pins are clean,and not burnt or use a new cord,the connection at the projector makes a GOOD connection with the new cord.
You will need a multimeter to check if there is voltage at the inside of the projector cord connection.You will have to remove the internal fuse before you check the the voltage inside.If all looks good then you will have a fault on the circuit board-shorted component on power supply side or further in on the circuit(need an electronic tech for this).Hope this helps--Jay
SAFTEY FIRST ALL TIMES--NOT SURE DO NOT DO IT
Oct 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
60 people viewed this question
Top Sharper Image Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sharper Image Office Equipment and Supply Expert? Answer questions, earn points and help others
