Question about GE Dryers
Timer and motor stop - GE Dryers
  • 34 Answers
I would recommend to anyone with major appliance problems, to do a search for "appliance guru" and just follow their lead for your particular symptom. I have had very good luck with them. Parts, in some cases, can be had at much lower prices. You're on your own for that.
Posted on Oct 12, 2013
I can hear my Malibu timer working, but it suddenly stopped being able to trip the lights on or off.
Motor has gone bad.
There is no direct 1:1 motor replacement.
Set timer to override and remove trippers... plug power pack into cheap wall timer.
Troubleshoot, installation and warranty tips on following link:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Gene
Water Heater Timers Save Money
Mar 04, 2015 | Malibu Hardware & Accessories
Intermatic e1010
Is this new timer installation, or older timer that stopped functioning?
1) Copy following link to help identify timer, download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
2) If this is new installation, then check wiring for single pole installation. This timer will not work for 3-way switching.
http://waterheatertimer.org/How-to-wire-timers.html
3) If timer worked before, and now clock motor has stopped working:
Turn power off, use compressed air to blow out timer, then see if you can spray highly flammable vapor from WD40 can into the motor.gears.
4) There are replacement trippers for this timer, but no replacement clock motors.
Buy another single-pole in-wall timer.
Dec 03, 2012 | Intermatic Hardware & Accessories
Why is my timer runnung backwards
Timer is not identified.
Analog timers have clock motor.
If the gears strip out, then timer can run backwards.
Some timers have replaceable clock motors, such as Intermatic and Tork box timers, and pool timers.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
While small plug in timers generally do not have replacement parts.
Jul 19, 2012 | Hardware & Accessories
The washer cycle stopped without warning, i thought the timer or the timer motor but it is not the timer works fine and so is the motor. but the timer motor runs til the washer motor starts than is the...
Confirm that the lid switch a common failure is working. A distinct click is usually heard when lid is closed. Temporarily by-pass to confirm and diagnose this type of problem. Confirm tab is in place on the lid.
Jun 28, 2017 | Jackson JPX-300L Dishwasher
Intermatic timer for my pool pump - clock is not running
Usually the timer motor is bad when that happens. Replacement timer motors are available from websites like this one:
http://www.aplussupply.com/intermatic/timermotors.htm
Be sure to get the right voltage timer motor. Intermatic T101's and T103's use a 120 volt timer motor (Cat# WG1570) and the T104 uses a 240 volt timer motor (Cat# WG1573).
If you don't want to mess around replacing the timer motor, you can purchase a new timer, and as long as the existing enclosure is in good shape, just swap out the guts.
May 12, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Timer stopped working Manual mode turns things
Usually the timer motor is bad when that happens. You can purchase a new timer motor here (or at a similar website):
http://www.aplussupply.com/intermatic/timer.htm
If you don't want to mess with replacing the timer motor can can buy another time clock and as long as your existing enclosure is still in good shape, just swap out the guts.
Apr 07, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
T104 clock stopped running. must now use switch
Yes, you can replace the timer motor to solve the problem. For the Intermatic T104 you'll need to purchase the 208/277 volt timer motor. Part number is WG1573.
If you don't want to mess with replacing just the timer motor you can purchase a new timer and swap just the guts with the old timer as long as the existing enclosure is still in good shape.
Mar 17, 2010 | Intermatic T101R3 110 volt time clock in a...
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Modle 80 washer question?
ck motor wiring connection for burnt or dark connections also possible bad timer ..have known timer to cause motor to run both speeds at same time this causes motor to overheat and shut off
Aug 16, 2008 | Kenmore 22422 Top Load Washer
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
32 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
