Question about Yard Machines Garden
Steering colunm model 700
Steering is very sloppy on my 42 inch ride on. The bushing / gear is noticeably wore. Does the steering colunm have to come out
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Yes
Posted on Oct 22, 2013
Steering skips
Three things need to be checked. The steering shaft for play, the pinion gear on the end of the steering shaft and your stationary gear at the bottom. Raise the hood, turn the wheel back and forth so you can see where the play is coming from.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to fix loose steering
Change all the bushings in the steering gear. Where the tie rod connects to each front wheel and , the one where the steering shaft is resting.
Apr 05, 2014 | Craftsman 42" 19.5hp* Automatic Lawn...
Steering only turn to left side
You will probably need to place the steering shaft gear and the sector gear and the lower bushing. The original cause of failure is likely the lower bushing where the steering shaft goes through the frame. It probably wore out allowing the shaft to move away from the sector gear allowing the gear teeth to skip on each other.
Oct 22, 2012 | Garden
Steering is loose. How to tighten it?
Joseph, Most likely it is the bronze bushing at the other end of the steering shaft. You will need to remove the mower deck to access it more easily. The steering gear could be replaced at the same time if you want, you will be right there at both the bushing and the gear, the sector shaft hopefully is ok. You can view this with a flash light before disassembly. It is on the steernig shaft that goes behind the fuel tank, down into the frame. As you or a helper turn the steernig wheel back and forth, you can see the engagment of the steering gear and the sector shaft, to determine if they need replacing too. Your dealer should have a dozen or so of those bronze bushings. Its not a bad job to do.
Matt
Nov 09, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My Cub Cadet riding mower won't turn. It just makes a clicking sound as you turn the wheel??
sounds like teeth on fan gear are worn or steering shaft and gear came away from fan gear. if fan gear worn replace if ok loosen lower steering shaft mount push tward fan gear and tighten, grease front steering spindles. or may need to replace spindle bushings.spindles too tight causing fan gear priblem
Jul 15, 2010 | Cub Cadet 42 And 54 Inch Blade Operator's...
My steering wheel will not turn towards the right. it sounds like it stripping gears. How do i repair it?
raise the hood and follow the steering wheel shaft down ti the gears. u either have gears stripped or a worn out bushing.get parts and replace or have a lawnmower repair person do it.
May 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hit Object - Steering gear shifted....decreasing right turn to 15 degrees...increased left turn to 90 degress. How best to reset?
look down at the base of the steering column and you should notice that the steering is like two gears faceing each other. when you hit an object hard enough it is possible for the gears to jump out of alignment, simply loosen and realign, gears should be facing each other equally, to give you the same turn radius, left and right
Oct 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
24 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
