Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Looking for power cable for Pinpoint 7520 fish locator. Where can I find one.
06 Lincoln Navigator liftgate opens okay but need help to close why?
Power Liftgate
The power liftgate feature will allow the customer to automatically OPEN or CLOSE the liftgate by activating the interior open/close switch, the remote keyless entry transmitter or by manually initiating liftgate movement. The power liftgate uses a power cinch system to latch the liftgate.
The power liftgate system consists of the following:
  • Power liftgate control switch (located in the overhead console)
  • Power liftgate motors (located in the rear headliner area)
  • Optical sensor and power liftgate encoder wheel (located in the left power liftgate motor assembly)
  • Pinch strip switches (located on the body by the liftgate)
  • Home position switch (located on the cinch actuator)
  • Forkbolt switch (located on the cinching latch assembly)
  • Detent switch (located on the cinching latch assembly)
  • Liftgate close chime module (located in a unit external from the power liftgate module)
  • There are a lot of electrical switches an motors
  • Visual Inspection Chart Mechanical Electrical
    • Power cinching latch and linkage
    • Power liftgate pinch strip switches
    • Liftgate and liftgate hinges
    • Liftgate assist cylinders
    • Liftgate strikers
    • Exterior release handle and linkage
    • Liftgate weatherstrip
    • Liftgate alignment to body and striker
    • Central junction box (CJB) fuse:
      • 5 (7.5A)
      • 105 (30A)
    • Wiring harness
    • Connectors
    Are you willing to take the back hatch apart to test this ,to find a fix . But first have it check for DTC'S - diagnostic troulbe codes '
  • Power Liftgate Module Diagnostic Trouble Code (DTC) Index
    Power Liftgate Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Defective Power Liftgate Module INSTALL a new power liftgate module. REFER to Power Liftgate Module in this section. B2477 Module Configuration Failure Power Liftgate Module REFER to Section 418-01 . B2522 Vbatt1 Circuit Failure Power Liftgate Module Go To Pinpoint Test B . B2552 Vbatt2 Circuit Open Power Liftgate Module Go To Pinpoint Test B . B2698 Vbatt2 Circuit Failure Power Liftgate Module Go To Pinpoint Test B . B2699 Left Pinch Strip Open or Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2700 Right Pinch Strip Open or Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2701 Left Pinch Strip Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2702 Right Pinch Strip Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2703 Open/Close Switch Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2704 Optical Sensor Power Short to Ground Power Liftgate Module Go To Pinpoint Test B . B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement Power Liftgate Module Go To Pinpoint Test B . B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement Power Liftgate Module Go To Pinpoint Test B . B2709 Gate Open Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2710 Gate Close Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2711 Gate Open Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2712 Gate Close Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2713 Unlatch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2714 Uncinch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2715 Cinch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2718 Gate Ajar Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2721 Gate Ajar Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2722 Open/Close Switch Active During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2723 Glass Position Switch Active During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2724 Forkbolt Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2725 Detent Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2726 Home Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2819 Gate Motor Circuit Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2820 Gate Motor Circuit Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2821 Cincher Motor/Unlatch Actuator Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2822 Cincher Motor/Unlatch Actuator Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2825 Movement Ceased Due to Excess Speed Deviation Power Liftgate Module Go To Pinpoint Test B . B2903 Chime Output Circuit Short to Battery Power Liftgate Module/ Liftgate Chime Module Go To Pinpoint Test C . C1935 Chime Circuit Failure Power Liftgate Module/ Liftgate Chime Module Go To Pinpoint Test C . U1950 UBP Communication BUS Fault UBP Communi- cation REFER to Section 418-00 . U2338 Invalid ACM Message Data Power Liftgate Module REFER to Section 418-00 . U2242 Invalid 4WAS Message Data 4WAS Module REFER to Section 308-07A . U2403 Invalid CSM Message Data Vehicle Security Module REFER to Section 418-00 . U2406 Invalid IC Message Data Instrument Cluster Module REFER to Section 413-01 . U2469 Power Liftgate Disabled By Customer Interface Instrument Cluster Module Turn power liftgate on at message center. U2470 Unexpected Keyfob/Keypad Button Press Power Liftgate Module Go To Pinpoint Test A . U2471 Unexpected PRNDL State Power Liftgate Module REFER to Section 419-10 . U2472 Unexpected IGN State Power Liftgate Module REFER to Section 418-00 . U2473 Unexpected Vehicle Speed Instrument Cluster Module/ Powertrain Control Module REFER to Section 413-01 . U2528 PRNDL Data Mismatch Power Liftgate Module/ Instrument Cluster Module Go To Pinpoint Test D .
Feb 13, 2017 | 2006 Lincoln Navigator 4x4
I am in need of a power cord for a Pinpoint 7520 locator can anybody steer me to where I can get one?
what car>???????????
Problem with Cars & Trucks I am in need of a power cord for a Pinpoint 7520
Oct 12, 2013 | Cars & Trucks
HDs 8--detecting bait fish?
its hard to describe a school of bait fish on the screen less you know what your looking at you need to go on line to www.lowrance and go to there what bait fish looks like on your screen page it will show you all you need to know and how to set your unit to know what your looking at and how to read your screen on your unit
Feb 06, 2013 | Lowrance HDS-8
I need a power cord for a Tournament Master HR Bottom Line fish locator. Where can I find this cord?
Do you still need the power cable? I have a new unopened power cable.
Dave
Feb 10, 2011 | Boating
Where is the power button on a blackberry 7520
The power button on the BlackBerry 7520 is located at the bottom right of your keyboard. The one that looks like a sun.
You can contact me if you still need help.
Regards,
BES Tech
Nov 09, 2010 | RIM BlackBerry 7520 Handheld
Which key do we need to press to enable a wireless connection?
Hello, looking at the manual for the 7520, just below the power button that is in the top-centre of the keyboard, is a row of buttons called the 'easy launch buttons' The left-most one has a sort of scripted 'e' symbol on it, and the one next to it has a symbol meant to look like a satellite dish ..(well kind of...) ,well, that's the one you want!
Hope this help you.
Regards,
Nicam49
Oct 16, 2010 | Acer Aspire 7520-5185 Laptop
Aspire 7520-5757 will not power on. How can I fix it? Is there a hard reboot that I can do?
Yes there is. Ill teach you how. Turn off your pc, remove the cables and battery. Then press and hold the power button for 8 seconds. Reinsert the cables and battery and turn on the pc. Check the lights on the keyboard if it still on. If it is not, then the problem might be the internal power supply inserted on your laptop or the motherboard itself which is situated inside of your laptop. If you do not know how to reseat or remove the parts of your laptop, then call ASUS for possible repair of it. Bonafide ASUS technicians will handle your concern...
Jul 07, 2010 | Acer Aspire 7520-5757 Notebook
I have an old Magellan Meridian XL that has the power cable missing and I cannot locate another cable. Anyone know the pin configuration so I can make up a cable ? Power only, no data in and out.
Hi yakabofski!
There are TWO configurations of the pins with these units. We have the FIVE-pin config and the assignments are as follows:
Top pin- 12v
Bottom pin- ground.
Hope this helps.
Apr 06, 2010 | Humminbird Fishing GPS Receiver
Acer Aspire 7520 turns off and on repeatedly
it looks like your mainboard is cutting the power. mainboard has power issue. need to get service.
May 30, 2009 | Aspire Acer 7520-5071 Notebook
Camera cord
It's the same cable that the Sony DSC-S650 uses. If you search for a cable for the Sony, it is the same one that the SVP CDC-7520 uses.
www.zkarlo.com
Oct 21, 2007 | SVP CDC-7520 Digital Camera
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
