Question about Electric Kranzle Professional 1600 PSI Pressure Washer
Kranzle electric washer will not suck up soap
  • 47 Answers
Hi, if it has a chemical injector on the machine then the pressure at the lance will have to be lowered for it to pull in soap. it works on a similar principle to how carburetors on cars pull in fuel, bernouli principle. high pressure at one side of an orifice going to low pressure at the other side which causes a negative pressure ( vacuum) which should pull in the soap. there should be a non return valve at the orifice (hole) which prevents the water back feeding into the soap container, it is quite common for this valve to get stuck, it is just a ball, spring and o ring , and the ball sticks to the o ring. if it is this system then take the soap pick up pipe off the injector and just push the ball off it's seat with a bit of wire.
If it is a high pressure soap system then that is different, but they usually work with an injector in my experience.
try taking the high pressure hose off the front off the machine and running it, if it has an injector on it it should pull in plenty off soap.
hope this helps ,
andy
Posted on Oct 16, 2013
Adjust soap injector
If it connect to the outlet pipe/lance then it operates on SUCTION similar to blowing across the top of a beer bottle to make a noise. If thats the case it is a matter of blockage and ventilation of the soap bottle to allow air to enter as the soap is sucked out by the water flow.
Oct 23, 2015 | Northstar Pressure Washer 3000 PSI
Craftsman 1700 leak
craftsman 1700 pressure washer 1700 elect. with steam
it sucks down the soap down when I wash my golf cart. I do it fast any way slowing it diwn
Jan 28, 2013 | Craftsman 1700 PSI, 1.3 GPM Electric...
Unit running fine and it just suddenly cuts out. Is there any type of safety switches
if the motor cuts out, it is electrical, if the pump cuts out it may need a bypass unloader, or valves. If it has a soap valve, make sure it is closed because you may be sucking air
Aug 23, 2011 | Mi T M Garden
When washing dark colors there is a soap residue left on clothes,i have tried using very small amounts of soap as well as different brands of soap
Try using white vinegar in place of liquid fabric softener. Half a cup at the rinse cycle in a full load will do it. Trust me, the smell of the vinegar will fade quickly as it works to break down the soap.
There are two other possibilities here:
You're overloading the washer with clothes - An overfull washer has the problem of not providing proper drainage before the spin cycle starts - Soap ends up getting embedded in clothes instead of being sucked out of the drain.
Or, You're using non-HE soap in an HE washer.
Hope that helps.
May 04, 2011 | Washing Machines
Kranzle Pressure washer...seems to be no power to the machine..checked switch and all connections all fine but no power to the machine
Could be that the fuse in the plug needs replacing.
Does the machine make any noise? Does it buzz/hum when you try to turn it on? - If yes, a starting capacitor is required.
Nov 19, 2009 | Electric Kranzle Professional 1600 PSI...
Comet 2.5 Gpm pressure washer pump wont **** soap anyone know what you have to do to make it start sucking soap
I have found many comet pumps to be plumbed wrong from the factory. Look on the side of the soap injector and look for the flow arrow, make sure its in the right direction. If it has worked in the past,then take it apart and replace the spring, check ball and seat.
Nov 03, 2009 | Comet GXD2527G Pressure Washer Pump
Karcher G 2600 ph
Dear johnny_river,
In general there are many causes why soap is not sucked. In a domestic and various other machines the soap is only sucked in low pressure. So one thing you can try is remove the nozzle or the complete lance from your gun. This will give a low pressure. If you attach a pipe directly to the machine soap inlet, and soap is not sucked, than the soap valve is "stuck closed" with soap. It is important that one must work with fresh water after using soap. This to flash the system from any soap left. So in a few words attach a pipe directly to the nipple at the machine and use low pressure. Important , you do not have to use soap to test....use fresh water. If this works( which it should)...than service the flow control tap or change it altogether.
Regards,
fulltech.
Apr 09, 2009 | Karcher 2500 PSI Pressure Washer
Electric Kranzle Professional 1600 PSI Pressure Washer Logo
103 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
Mike
Are you an Electric Garden Expert? Answer questions, earn points and help others
