Question about Video Game Consoles & Games
When will this game be patches to work on wondows vista, 7 and 8 ? Been to long and no fixes yet
  • 122 Answers
It would help us if you told us what game you are on about.
Posted on Oct 16, 2013
Please some 1 say how 2 run brian lara 07 pc game in windows 7? an dialoge box appears saying it has stopped working.
Its supported os are WINDOWS XP/Vista.
HOWEVER not to worry. Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select either xp or vista and click apply.Stat the game and hopefully it works.
Oct 01, 2012 | Codemasters Brian Lara International...
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
I've installed Cossacks(the Art of War) in Windows 7 Professional. HP-Pavilion Slimline s5710F.The game come up with double vision still can't play,everythink runs together.
I think there is a form of copy protection that installs a driver onto your computer. It was originally designed to be used on Windows XP only. In order to fix this issue, you'll need to contact the game developer for an update or patch that allows you to install the game. There is no other work-around for this, because Starforce contains a driver that Vista will not accept because it is built for another operating system. Starforce protected games are well known to be one of very few XP titles that will not work on Vista without an update or patch, due to its design.
    You can give this a go too... http://m0001.gamecopyworld.com/games/pc_cossacks.shtml
    Mar 19, 2011 | Strategy First Cossacks: European Wars for...
    I've install Cossacks (the Art of War) in Windows 7 Professional. HP Pavilion Slimline s5710F. the game come up with double vision,still you can't play with everythink running together.
      CivCity Rome shuts down windows on vista laptop
      That's wierd... O.K. yeah, its probably the vista thing... Or it might be the download. When you downloaded the game you might of gotten a faulty copy i.e. the game file has a virus. If it is the "vista" thing, than download the game onto another computer that can play it. Like how you said the game would work fine on your old XP PC, than it sounds like that's the computer you have to use. My advice, keep looking for different downloads to get the game, and keep searching for patches to try and fix the problem, if all else fails buy the game or call tech support. Hope this helps
      Dec 28, 2008 | Take 2 Interactive Civ City: Rome for...
      Monster Madness: Battle for Suburbia not working
      a large number of older games do not work on vista, they are incompatible, you can either download the patch from the games site, which i see youve tried and it did not work, in this case, try to run the program in windows xp SP2 mode. to do this, fidn the application or executive file, it will have .exe at the end of the filename or will say application, then right click it, properties, compatibility, then check the box to run in compatibility mode for:, then choose for Windows XP (Service Pack 2), use those settings then try it again, if it still doesnt work then you simple can not use that game on vista. your last option you can try has a small risk of virus, only because it is user created, but seacrh the internet for a patch that allows it to work on vista. some people make their own patches to allow the program to work on vista.
      Dec 03, 2008 | South Peak Interactive Monster Madness:...
      Will rrt3 work with vista
      Try running the game in Compatibility mode. Right click on the game icon, go to Compatibility at the top, then check the box that says "Run in compatibility mode". Then select the compatibility mode for the reccomended operating system for the game.
      Nov 21, 2008 | Take 2 Interactive Railroad Tycoon 3 for...
      Unable to load TalonSoft East or West front
      Sorry friend but this game is not compatible with Vista and there aren't any patches. However you can try your luck here. Go thru the thread http://www.theblitz.org/downloads/patches.php#cs
      Also i suggest you to run the game with the Xp Sp2 Compatability option turned on.
      Oct 09, 2008 | TalonSoft East Front 2 for Windows
      Adobe acrobat reader 7 has problem with window vista need upgrade or patch to fix problem
      acrobat 7 is not compatible with Vista, you need to upgrade to acrobat reader 9, it's free from here
      Sep 01, 2008 | Computers & Internet
      Installing
      Well sir that depends on the game itself, whether its creators want to make patches to play it on vista or not, try seeing the game author's site for more information.
      Nov 17, 2007 | Microsoft Windows Vista Ultimate Edition
      Video Game Consoles & Games Logo
      24 people viewed this question
      Top Video Game Consoles & Games Experts
      James Wishart
      Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
