Asrock P4vm900-SATA2 motherboard is beeping, no display on screen, cpu fan running
cropp
  • 377 Answers
SOURCE: No beep,No Display on my monitor,only CPU heatsink fan is moving
dear reclane
theat sound is sign of memory needed to your motherboard, try using a brush to clean your memory, after that you can put your memory again
or you can try to clear cmos with short the jumper the right next battery cmos, short pin 2,3 and power on yor pc. after that put in normal position
the last try to change your power supply with a new
oke
i hope it can solved your problem
thx
cropp
Posted on Mar 17, 2008
  • 55 Answers
hey
there might be problem with SMPS also. I mean there is one signal comming from SMPS - Power Good
if that singal is not comming then machine shows this kind of symtoms.
To check Power Good from SMPS -
Requirements ->
a) small wire/ pin
b) Multimeter
Procedure ->
1) Disconnect all power supplies going OUT from SMPS.
2) Locate the Orange Wire , Green Wire, Blackwire
3) Now insert small pin / wire into Black + Green wire (Make them SHORT) and provide power to SMPS --> SMPS will get started.
4) Now check the Multimeter rating for Orange wire --> it should not be less / more than 3.3 - 3.6 volts. --> If it is less / more then there is problem with your SMPS and you need to get it repaired.
5) In india it will take near about 100-150 Ruppes to repair SMPS.
alternate ->
You can replace your SMPS with other working SMPS (best option will be your friends system) and check whether same symptoms occurs or not.
Other Damedge -
If SMPS is working fine then there must be problem with FEW SMDs available on your motherboard. For this repairing in INDIA it should not cost your more than 600-700/-
Posted on May 29, 2008
yalmer
  • 552 Answers
SOURCE: motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Posted on Jun 14, 2008
v_suspect
  • 27 Answers
Obviously, it could be a transcient error or what we call the soft error. There could only be two culprits if you encountered this kind of problem. One is, it could be the power supply. If the power supply is faulty the electricity that flows within it (which is AC converted to DC)could have a lower or higher amount of electricity instead of a normal rate.
But if your PSU is working properly ( you could check it by swapping the PSU to another system unit ) then it could be the MOBO. According to standard IBM POST error codes, no beeping sound could be a faulty PSU or MOBO. It is more practical but to replace the MOBO, but still you could use the memory, videocard, HDD and other devices.
Posted on Sep 05, 2008
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Posted on Jan 13, 2009
I have a m,b, asrock 845 presscot mothwer board cpu fan is running but not booting and not display .
are you getting any beeps. These can tell you what your problem is. Just google asrock beep codes
Aug 25, 2010 | Asrock 845GV (P4I45GV) Motherboard
THIS MOTHERBOARD SUPPORT PROCESSORS WITH 2 CORS ?
http://www.asrock.com/mb/cpu.asp?Model=K8NF4G-SATA2
looks llike you can put an amd Sempron-64bit cpu in.
Oct 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
CPU Heatsink is cool but fan runs fine no display
No beep or sound means Motherboard Defective, aside from Processors is OK, Memory is OK, and the rest!
Buy a new one not as the same Motherboard you use. ASROCK Motherboard are have a a problem when high temperature occur.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 29, 2009 | Asrock P4I45GV R5 Motherboard
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Simon Mezoa
se necista a installar los drivers.
pude a ir a este web site , para verificar caul drivers tiene que installer
http://www.asrock.com/mb/cpu.asp?Model=P4VM900-SATA2
Thank you
thewho1
Aug 03, 2008 | Asrock Pentium 4 (LGA 775-pin) -...
Driver graphic integrer
You may want to try going to the asrock download page for this motherboard http://www.asrock.com/mb/download.asp?Model=P4VM900-SATA2 I would suggerst installing the via 4-in1 driver, if this does not cure the problem please provide which video card (make and model) your system has.
Jun 18, 2008 | Intel Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
