Question about Canon PowerShot S5 IS Digital Camera
Hy guys. I am having a problem with my Canon S5 IS. Before pressing the trigger button the picture I see on the display looks ok (bright and sharp) but after taking the picture (or even when pressing shutter halfway to focus) it becomes dark. It seems that in the auto mode, the ISO value falls to 80 after pressing shutter button, no matter how intense the light is. In manual mode similar thing happens.The problem is most pronounced when taking photos outdoor.
    Sergeant:
  • Canon Expert
  • 488 Answers
This is a very odd problem. I wonder if you've got the depth of field preview button activated. As you look at the camera from the front there is a button on the left below where the lens meets the body roughly at 7 'o'clock That is usually the the DOF preview button. Try a little fiddle with that.
Posted on Sep 02, 2015
markevans
  • 148 Answers
SOURCE: CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Posted on Dec 24, 2007
old marine
  • 2098 Answers
SOURCE: Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
Posted on May 01, 2008
HeavyDLB
  • 46 Answers
SOURCE: Canon S5 IS. I
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
SOURCE: photos are not sharp
I would look beyond the camara and suspect that the computer is tired or overloaded. This would be a more logical point of defining the trouble and cheaper than suspecting your fine camara and expertise. If you still think it is the camara take it off the auto focus for a few weeks and see if you still get problem shots. If So take the puppy in for an overhaul of the timing shutter mechanism. It may just have a fuzz ball or rather hairball problem that only momentarilly and intermitintly snags. If it is not the auto focus then how about a different computer program choice?? Photo files eat up a lot of space and unless you have one computer that is totally dedicated to just the storage fixing and printing of the pictures you may simply have a RAM vs PIXEL problem. Try off loading some onto disc for storage instead of keeping them all on the machine. If they print out better in quality than you see on your screen then it may be your monitor that needs to be reset to handle fine detail in the contrast settings. You may have to upgrade this equipment, which I would for the TAX BREAK.
Posted on Nov 21, 2008
pontelemon
  • 538 Answers
SOURCE: Shutter don't stop halfway
Yes, there is a small 2-stage micro switch that needs to be replaced. 1st stage is permanently pressed and not switching/returning back due to so many time it's been pressed.
It just time. Switch is right under top cover.
Posted on Apr 26, 2009
How can I get the LCD to turn on?
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
  • Press once for Normal view in LCD viewfinder
  • Press twice to turn on Rule of Thirds grid lines
  • Press three times to turn off LCD display
  • Press and hold 1 sec. to decrease/increase LCD brightness
Jul 20, 2014 | Canon Cameras
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Is there a way to access the tint function on the Apex4088? It is not accessable when we go into the picture setup menu. It appears to be locked.
Hello
The Tint function can be accesed by the following steps.
The PICTURE menu offers options to enhance and refine the picture displayed on your TV based on ambient room light and personal preferences. Adjustment options include contrast, brightness, color, sharpness and color temperature
Press the MENU button on the remote control. Navigate using t u arrow buttons to select PICTURE. Press the down q arrow button to highlight PICTURE MODE, then press the u arrow button to select your viewing preference from 4 factory options:
STANDARD > DYNAMIC > MOVIE > PERSONAL. The STANDARD setting is recommended for most viewing environments. Depending on the ambient light level in the room, you may find one of the other options more pleasing.
To make more critical adjustments based on your own preferences in PERSONAL:
• Use down q arrow button to highlight Contrast. Navigate using the
t u arrow buttons to increase or decrease contrast intensity.
• Use down q arrow button to highlight Brightness. Navigate using the t u arrow buttons to increase or decrease overall brightness.
• Use down q arrow button to highlight Color. Navigate using the
t u arrow buttons to increase or decrease color intensity.
• Use down q arrow button to highlight Tint. Navigate using the
t u arrow buttons to adjust colors toward green or reddish tint.
• Use down q arrow button to highlight Sharpness. Navigate using the t u arrow buttons to soften or view crisper edges in the picture.
• Use down q arrow button to highlight Color Temperature. Navigate using the t u arrow buttons to select COOL (more bluish tone), NORMAL or WARM. The default setting is NORMAL. WARM mode will provide color that is calibrated to D6500° Kelvin, the standard color that broadcast stations and the Motion Picture industry consider as the most accurate to view programming.
Note: When adjustments are completed, you may select another menu by pressing the Menu button.
OK
Jan 14, 2011 | Apex Digital LD4088 LCD TV
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
Canon MP600 - changed to chinese!
Cause
Action
The language you want to be displayed is not selected.
Select the language you want to be displayed according to the following procedure.
(1) Press the HOME button. Wait for about 5 seconds, select , and then press the OK button.
(2) Press the button to select the pliers and screwdriver icon , slide the window to highlight the LEFT selection, looks like 2 horizontal lines w/ arrows at either end, NOT the 4 color ink drop display, then press the OK button.
(3) Press the down button four times, then press the OK button.
(If the Bluetooth unit is connected to the machine, press the button five times, and then press the OK button.)
(4) Press the down button to select the language you want to be displayed( english), then press the OK button.
Voila! done! hope it helps.
Jul 13, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I have a canon powershot s5 and i wanted to know how can i change the brightness, contrast, saturation, etc.
You want to use the custom setting on the camera. You can see what the icon looks like and the specifics on page 91 of the PowerShot S5 IS Camera User Guide Advanced version here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=15207#DownloadDetailAct
The custom setting will allow you to balance/adjust the brightness, contrast and saturation before you take a picture.
Apr 30, 2008 | Cameras
How to delete picture from canon powershot s5is
Press the set button located above the menu button to erase a single picture. The set button is like an enter button on a PC
Apr 25, 2008 | Canon PowerShot S5 IS Digital Camera
From chinese to english
Right from Cannon:
Issue:
How do I set the language?
Solution: Procedure for setting the language PowerShot S5 IS.
Setting the Language
The language in which menus and messages are displayed can be selected with this function.
Method 1
  1. Power the camera on in the playbackicon.gif (Playback) mode.
  2. Hold down the <SET> button and at the same time press the <MENU> button.
  3. Use the direction_arrow_up.gif, direction_arrow_down.gif, direction_arrow_lt.gif, or direction_arrow_rt.gif button to select a language and press the <SET> button.
Method 2
  1. In the playbackicon.gif (Playback) mode press the <ON/OFF> button until the power lamp lights.
  2. Press the <MENU.> button to display the Rec. or Play menu.
    - Use the 023.gifbutton to select the setup_icon.gif(Set up) menu.
    - Use the 021.gifor 026.gif button to select LANGUAGE and press the <SET> button.
  3. Use the 021.gif , 026.gif, 023.gifor 028.gifbutton to select a language.
  4. Press the <SET> button.
  5. Press the <MENU> button to redisplay the Rec. or Play screen.
Oct 12, 2007 | Canon PowerShot S5 IS Digital Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Press the OK/MENU button and then press the right arrow button to enter the Mode Menu. Press the down arrow button until the SETUP tab is highlighted. Press the right arrow button and then the down arrow button until PIXEL MAPPING is highlighted. Press the right arrow key, which will highlight START. Press the OK/MENU. The back of the camera will display an indicator bar with the word BUSY. Once Pixel Mapping is completed the Mode Menu displays. Press the OK/MENU button to resume normal picture taking. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
