Question about Sony BDP-S300 Blu-Ray Disc Player
Code for RCA tv from remote BDPS3100 - Sony BDP-S300 Blu-Ray Disc Player
  • Craig Beske Oct 12, 2013
    Manual says code is 10 - but no workie. Perhaps it's some other TV with a Sony name on it? Model is 22LA45RQD Mfr label say On Corp USA. Any guesses out there?
Need code for RCA Universal remote RCR314WR To set up RCA TV detg188r
Here's a link to the RCA RCR314WR remote control user manual and code list:
Information Owner Manual Remote Code List and Support for the RCA RCR314WR...
Click on the link for the codes to find the code you need for your RCA TV
Apr 10, 2016 | RCA Universal Remote Control
What to use a rca universal remote butdont know the code
3 Ways to Program an RCA Universal Remote - wikiHow
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
Program an RCA Universal Remote Without a "Code Search"
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
Programming the RCA RCRN04GR Universal Remote
Dec 25, 2015 | RCA Televison & Video
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
QUIERO SABER CUAL ES EL CODIGO PARA UNA TELEVISION SHARP SP
aver si te ayuda esto
Code 000 for RCA TV Code 003 for RCA TV Code 004 for RCA TV Code 005 for RCA TV Code 006 for RCA TV Code 007 for RCA TV Code 019 for RCA TV Code 054 for RCA TV Code 055 for RCA TV Code 082 for RCA TV Code 096 for RCA TV Code 098 for RCA TV Code 099 for RCA TV Code 100 for RCA TV Code 101 for RCA TV Code 102 for RCA TV Code 103 for RCA TV Code 129 for RCA TV Code 179 for RCA TV Code 181 for RCA TV Code 188 for RCA TV Code 190 for RCA TV Code 196 for RCA TV Code 202 for RCA TV Code 203 for RCA TV Code 212 for RCA TV Code 215 for RCA TV Code 233 for RCA TV Code 281 for RCA TV Code 352 for RCA TV
estos son los codigos
May 05, 2010 | RCA RCU600M Remote Control
How to program for panasonic tv?
from http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR350
Code 1003 for Panasonic TV
Code 1054 for Panasonic TV
Code 1062 for Panasonic TV
Code 1109 for Panasonic TV
Code 1170 for Panasonic TV
Code 1248 for Panasonic TV
SEE ALSO
RCA Universal Remote Control Programming Codes
http://www.thompsontv.com/rcarc.html
Good Luck!
Apr 13, 2010 | RCA RCR350 Remote Control
We have a RCA remote and need the codes for an Emerson TV. Can you help?
The codes to program an RCA RCU300WBL remote control for an Emerson TV are:
Code 004 for Emerson TV Code 006 for Emerson TV Code 012 for Emerson TV Code 023 for Emerson TV Code 025 for Emerson TV Code 026 for Emerson TV Code 029 for Emerson TV Code 030 for Emerson TV Code 033 for Emerson TV Code 035 for Emerson TV Code 036 for Emerson TV Code 037 for Emerson TV Code 038 for Emerson TV Code 041 for Emerson TV Code 042 for Emerson TV Code 043 for Emerson TV Code 046 for Emerson TV Code 047 for Emerson TV Code 048 for Emerson TV Code 049 for Emerson TV Code 073 for Emerson TV Code 123 for Emerson TV Code 162 for Emerson TV Code 171 for Emerson TV Code 177 for Emerson TV Code 179 for Emerson TV Code 191 for Emerson TV
If you have a different RCA, remote control you can post more details, or take a look at the RCA Code Finder Website at:
Aug 08, 2009 | RCA RCU300WBL Remote Control
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
"I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Jun 03, 2009 | RCA Universal Remote Control
RCA remote codes lost
Codes For Model RCR311B
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
May 26, 2009 | RCA RCR311B Remote Control
Code for rca rcr311b remote to sharp tv
Feb 04, 2009 | RCA RCR311B Remote Control
Sony BDP-S300 Blu-Ray Disc Player Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
