Question about LG WM2688HWM TROMM SteamWasher
My washer LG2487 got something wrong it seems like a fuse problem . Is there inside a fuse or a reset
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
They don't have fuses. Look Here: I will help you. First, I assume you have a working outlet and your circuit breakers do not reset or go off. Next are you hooked up to an ac outlet that has a circuit breaker in It (at the outlet) if those are OK, then I have to ask...Are you dumb enough to put your machine on an Extension Cord. If NO...Thenk God you not that Stupid! If everything else checks out to here try this. Make sure you have Cold water and it is ON! Run the machine with COLD WATER Only! If this still causes the problem and you have checked ALL Your WATER In lines are Clear and Free of Rust, kinked hose, and good water flow then we come to the End of the Road Almost! If the machine just Stops something is cuasing It to do this. Usually it is because the machine cannot get Water OUT of it to Drain!!! This is a COMMON problem and you need to order a New Drain Pump. YouTube has an extensive library of videos that show how to install them. If this is above your Knowledge Bank. Then you either Call For Repair Service Like Sears. Or if your machine is more than 7-10 yrs Old. Run the spin cycle very fast and throw a Concrete Block inside it! You need a New Machine cause your electrical panel is a goner. That is $400 Plus to repair!!! Hope this helps.
Whatever you do ...Do NOT cal LG! They are Idiots, They make TV's, Phones, Stereos! They are NOT Appliance Savvy With Washers or Dryers! That is why there are so many complaints. Hey don't Kick yourself to hard! I bought One too! Remember these two Words....Whirlpool and Maytag
Posted on Dec 17, 2013
How do I reset all codes?
I don't know what kind of washer you have but fault codes usually indicate that something is wrong. You don't just reset them.
You might find some help here but you will have to change the search terms.
washer error code YouTube
If you have your model number you may find help at sears parts direct.
http://www.searspartsdirect.com/
Nov 07, 2014 | Washing Machines
I have checked the plug fuses but there is still no power to the machine
Check the power from your wall outlet. Less than 112VAC, it will not power on. If good, check continuity from individual plug terminals to their corresponding wires. (should be disconnected from appliance first to avoid false readings), if bad, replace cable.If good, check voltage at positive side of incoming terminals at back of connection point and then individual fuse positives, then negatives. (while current is applied) , if good, could indicate a short in the circuit board, or a board fuse, or heater fuse on the motor, or bad display panel. In which case it no longer becomes DIY.
Jun 03, 2014 | Miele W864 Front Load Washer
Whirlpool washer blows fuse
the pump motor is starting to seize up. It is causing the motor to work harder which causes heating of electronics causing the fuse to blow
Feb 21, 2012 | Whirlpool LSQ8543J
My washer seemed to have just died. I have unplugged and am still getting not response. I have a Duet Whirlpool model.
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello. The mains fuse was blown.. replaced it now the washer won't fill with water
Fuses blow to protect other parts in electrical items from being damaged ;-0)
So- something inside the washer caused the supply current to exceed that of the fuse. Sorry, with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
John C
Apr 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer was displaying 06 (I think). I tried to reset it and then there was a loud pop and all the lights went off. Now it seems there is no power going to it but at the same time the door is locked and...
Open the back panel and look for the main fuse. Check the main fuse, if blown replace w/ the same value of amp.
The fuse just blown off, means there is something wrong w/ the electrical system, the capacitor might have been overheating. Call a technician so that he could pinpoint the main cause of a BLOWN FUSE!
Nov 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not start, no power, had power failure for 24 hrs after power came on washer will not come on, there is power in the outlet. is there an internal fuse or reset button, manual unavailable,...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 09, 2010 | Washing Machines
I have an old Maytag top loader washing machine. The lid id broken so I have to flip it upside down and backwards to keep the button depressed for washing. The lid kept jiggling loose and I would have to...
Check the thermal fuse. It is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown fuse. Hope this helped and best wishes.
Aug 05, 2009 | Washing Machines
MAYTAG MAH5500BWW
No power
Lid switch
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 60 series washer
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
