Question about Toshiba Portege R705-P35 Laptop
Power light flashing lightning
What is the solution?
Need instruction on how to put the flash for vivitar vivicam 8025
Repeatedly touch the lightning bolt function area to cycle through the flash modes. Lightning bolt with a letter "A" is automatic (camera decides whether flash is needed), lightning bolt is forced flash (always flashes), eyeball is red-eye reduction, lighting bolt in circle with slash through it is off (never flashes).
Aug 18, 2010 | Vivitar ViviCam 3915 Digital Camera
I want the camera to flash when there is a light background, but not enough light on the subject. can i force a flash? Jim
Yes.
Press the flash button (the lightning bolt symbol on the up-arrow) to cycle through the settings. It's probably on Auto (lightning bolt with the letter "A"). Switch to On (lightning bolt).
Don't forget to switch back when you're done, or you'll always get the flash.
Jun 17, 2010 | Canon PowerShot A630 Digital Camera
How do i turn off the flash on the cannon power shot a530
Press cursor-up on the round cursor pad (marked with a lightning bolt) to change the flash modes. To turn the flash off, select the lightning bolt in a circle with a slash through it.
May 15, 2010 | Canon PowerShot A530 Digital Camera
Lightning struck now my tv won't work.
No,Ur power supply board have a big jolt massive power search.It dead,change the power supply board,will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 08, 2010 | Insignia NS-LCD22-09 LCD HDTV
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
After lightning, my television did not work
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here.
Mar 15, 2009 | Toshiba 32AF41 32" TV
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Can Flash be Forced to On
Yes, open up the flash and press the flash button once (the button's on the back of the camera). Hope this helps.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Toshiba Portege R705-P35 Laptop Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
