Question about ASUS K52F-BBR9 Notebook
My Asus laptop model K52J battery icon is blinking Red, whether the power cord is plugged in or not. I always had my power cord plugged into my laptop day and night and never plugged it from the socket. What do I do to solve this problem?
    Problem Solver:
  • 7 Answers
It sounds like you're battery has died, has you've possibly over charged it. You will find new battery's online cheaper than actually going to some sort of shop. Just simply type in the model name on google and add battery. :) Hope this helps
Posted on Oct 14, 2013
SOURCE: ASUS laptop model A6000 Power supply
I have a similar problem. The laptop switches into battery mode irregularry, even if no battery is inside. It runs stable with power cord connected for some minutes or hours, but sometimes switches off with no warning.
I have taken a new power cable, but still the same problem. The battery is broken, it only lasts some minutes.
Posted on Aug 25, 2008
SOURCE: ASUS K52J Built in web cam picture upside down.
same here! tried updating device, but it wont work. downloaded manycam and it couldnt initialise for some reason AND u cant uninstall it since its continuously running!?!? now i just hope i could find a better free application i could download.
Posted on Oct 26, 2010
Joed911
  • 4338 Answers
SOURCE: How to enable wireless on
Try:
Asus ---- Fn + F2 (some models may have a switch)
Posted on Nov 30, 2010
  • 2567 Answers
SOURCE: I lost my power cord
You will need to buy another power cord for the exact model of your laptop. You can either find it in local computer stores, or you can search for it on ebay.com (usually search by laptop make & model, & usually buy from a top seller).
Posted on Dec 11, 2010
  • 31 Answers
SOURCE: i have laptop of ASUS K52J
Open your webcam program option setting, and find something like "flip" or rotate ?
That must be there in some place waiting for you to find out :D
Posted on Nov 16, 2012
Asus k52j flashing orange battery light
If you have access to a multi-meter check that the power brick is delivering the correct DC voltage at the plug that connects to the laptop. Remove the battery from the laptop and see if the computer runs.
The two common problems are either the power brick has failed in which case it can be replaced, (check ebay), or the battery has failed, same fix can be used.
Mar 04, 2014 | ASUS Netbook
When i pluged in my hcl laptop adapter the power led was blinking
when the battery is drained, the power-led blinks for a while until the battery has a few percent of charge, it will then go to solid red.
Dec 26, 2013 | ASUS 14 led i3-2310 laptop p43exh31
The battery led blinking red/green
Disconnect power cord. Please take out the battery. Hold down power button for a minute and then connect only power cord. Restart it again.
Jun 24, 2013 | ASUS Computers & Internet
Light is blinking but not video or set not running
Sounds close to a very common problem although not sure which light is blinking nor what is meant by 'set not running' so here is the solution that has worked for others with very similar issues
aptop Computer powers on but display not working
Most likely solution for the following brands:
Acer, Asus, Aspire, Compaq, Dell, Fujitsu, Gateway, Hewlett Packard, HP, Lenovo, MSI, Panasonic, Samsung, Sony, Targus, Toshiba
1. Power off PC
2. Unplug power cord from PC
3. Remove battery
4. Hold down Power On key for 30 seconds.
5. Plug in power cord.
-DO NOT replace battery in your PC
6. Power on PC
Battery may be subject to recall due to fire hazard.
Google :'recall your laptop make and model'
Please return to share results to help others.
Thanks!
Jimm Harmon
Nov 23, 2012 | Computers & Internet
I need a Hdmi driver for my Asus K52j notebook, I have a digitech wq7415 HDMI plug but it gives video to my tv but no sound where can I find the driver so it uses my tv sound?
not all hdmi on laptops give the sound if you wanna try re-installing the driver go to asus website and go to support/drivers and enter your model number in
Mar 26, 2011 | ASUS K52JRA1 Notebook
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Daughter got Asus K52J laptop for Xmas. All was fine but this morning/ inbuilt mouse is not responding, any ideas
disconnect all the external devices connected to the computer
remove the power cord from from the computer
remove the battery from the computer
press and hold the power button for 10seconds
after that reseat the battery and plug in the power cord
turn on the laptop
the issue will be fixed
Thank you
Jan 06, 2011 | Computers & Internet
Hi, i have an Asus K52J model, i purchased it in the end of August so its only a few months old. I am studying abroad in Italy for the semester and am starting to run into some problems. It started out...
In my case, the cursor jumps around when I'm typing. It could jump one line up or back to the start of the line.
Anybody with an Asus K52J ever encountered this problem?
Nov 13, 2010 | ASUS Eee 4G Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
ASUS K52F-BBR9 Notebook Logo
170 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
