Question about Bosch Drills
Smoke + burning smell when bosch cordless drill AL 1404 operated
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
rowdy45176
  • 2176 Answers
SOURCE: kawasaki 840079 Green 19.2 Volt Cordless Drill Just stop working
It is possible that you overloaded it in high range and maybe stalled it out. Usually when the motor burns it is from overloading/overheating. If this is a newer tool I would try and take it back for warranty repair and not say anything about the smell. Its worth a try, some of the motors for the cordless tools are around 50-60 dollars
Posted on Mar 11, 2009
  • 103 Answers
SOURCE: Ryobi cordless drill burning smell
your over using the drill on havy jobs
Posted on Apr 12, 2009
  • 42 Answers
SOURCE: makita cordless drill 6011D
It sounds as if the brushes may be bad / burnt / chipped. If you fire up the drill in a dimly lit area you will likely see sparks inside the unit. The smell is the ozone that the sparking creates.
I have an 18 volt DeWalt that sparks and smells like something inside is cooking if I use it. I use that drill occasionally and every time I do I think that sooner or later it is going to give up the ghost permanently.
Now, if I had a 120 volt plug-in-the-wall outlet drill that was doing that I'd deep six the drill and get a new one. They are cheap enough and you really don't want to be dealing with sparking with an item that could short circuit and cause some real harm or damage..
You could get it repaired, but that wouldn't be cost effective. Take a wire cutters, cut off the plug from the wire and discard.
The one thing I would not do with the drill is sell it at a yard sale. It just wouldn't very honest to do that.
good luck.
Posted on May 16, 2009
comax
  • 154 Answers
SOURCE: Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Posted on Jan 09, 2010
When I pull the trigger on my cordless drill smoke comes out of the vents and you can smell burning odor
The motor has jammed and burned out. It is probably not worth trying to repair.
If it is still within the warranty period take it back for replacement under guarantee
Feb 10, 2011 | kawasaki 840079 Green 19.2 Volt Cordless...
I was drilling a hole and my drill blow up with a burning smel
could be quite a few problems, did you overload or stall the drill, did you have adequate power supply? Quick test without knowing the model number and brand can you turn the bit or chuck with your hand? If it is cordless is the battery contacts burnt? If electric unplug and remove the handle halves and look at the armature/field for burnt windings or burnt switch, all which could cause a burning smell and shut the tool down, let me know and I will try and help further.
Dec 21, 2010 | Bosch Drills
Where can I obtain a circuit board for a bosch cordless drill charger, Charger is AL 2404, part number 2 607 255 185, also has D-70745 Leinfelden printed on charger
most tool manufacturers don't offer the circuit boards as a separate saleable part. I can't find anything at the Bosch website.
Jan 13, 2010 | Bosch Drills
Bad/cheap drill
I agree. Did you have a question?
Jul 23, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
When I use the drill there is a burnt smell afterwards...what is causing this?
Drillbits "burn" what you are drilling when there is too much friction. That is caused by a variety of things...including...lack of lubrication for metal work...and usually a dull drill bit in wood.
If you see no smoke comming from the point of impact...it might be your drill motor..check it out when you are using it...it could be dirty and need a good cleaning...or it could be burning out from excessive or improper usage.
Apr 24, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Apr 11, 2009 | Drills
Kawasaki 840079 Green 19.2 Volt Cordless Drill Just stop working
Mar 11, 2009 | kawasaki 840079 Green 19.2 Volt Cordless...
Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Aug 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
114 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
