Question about Morphy Richards Never Loses Suction 73411 Family And Pets Upright Bagless Vacuum Cleaner, Purple
Brush roller is there a reset button for the brush roller
  • Morphy Richards Master
  • 18,411 Answers
No it has a automatic cut out look on page 7 in the manual on the link below
http://www.morphyrichards.co.uk/Pdf/IB73411.pdfhttp://www.morphyrichards.co.uk/Pdf/IB73411.pdf
Posted on Oct 12, 2013
We have the Absolute Animal model. The brush does not rotate although there is suction via the wand. Is there a reset button somewhere. Thanks for any help you can offer.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 04, 2016 | Dyson Vacuums
Hi my name is Sapphire. I have a dyson DC24. The roller bar keeps cutting out, I can't depress the reset button properly and so it won't start up again properly without me trying for ages. The brush bar...
One possibility is a failing reset button, Another option is a bind causing excessive energy to spin it. This will cause the reset button to trip. Check the bearings in the motor and brush roll.
Nov 09, 2014 | Vacuums
Why the Dyson dc 41 roller brush will not turn?
Try these steps:
  • Check the button that turns off the roller brush to make sure you didn't press it by accident.
  • Unplug the vacuum and clear pet hair and other debris off the roller brush. It may stop as a safety feature if the roller brush is too restricted.
  • Make sure the belt to the roller brush is placed correctly and not broken.
  • Press the roller brush reset button. It may be located on the side of the vacuum's head, or inside the handle. The switch may need to be replaced if it's defective.
  • The roller brush is disabled while the handle is in the upright position, so tilt the handle backwards while testing the roller brush.
I hope that helps you!
Jun 21, 2014 | Dyson Dc 41 Ball
Red reser button pops out after a few seconds, The brush is clear of threads.
Remove the belt from the motor to brush and then try. If the reset pops then the motor unit is faulty. If it doesn't pop off then the brush assembly is jambed or hard to turn, sometimes caused by threads in the roller endcaps
May 28, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
How to fix brush roller on electrolux mdl EL8501A - Roller will not turn
check if there is a reset button, if so simply push the button..other wise make sure the hose a wands are connected properly.Chris
May 27, 2014 | Electrolux Vacuums
I have a kenmore progressive vacuum with a belt reset button that trips out everytime you try to vacuum. It does it in about 5 to 10 seconds. Can I bypass the reset button or can you help me determine...
A lot of times the reset button is tripping because there is a problem. The problem could be with the brush roller in this case. A lot of times I see this unit for repair and the end of the brush is so compacted with hair and debris that it has also started to melt. This will also "fool" the reset and trip off. If you are near a service depot try there, or try sears parts if you need to have the brush roller replaced.
Bypassing the reset button is not advisable on any machine.
Nov 03, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
The red button at the side of the roller brush to reset it on my dc24 rollerball doesn't seem to do anthing. What am I doing wrong the diagram shows that you push the button forward but I can hardly get my...
you need to use something small to push the red pin right in, make sure there is nothing blocked in the roller and this should reset the motor. The roller needs to be switched on next to the power button is well.
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
May 18, 2008 | Dyson DC07 All Floors Bagless Upright...
Morphy Richards Never Loses Suction 73411 Family And Pets Upright Bagless Vacuum Cleaner, Purple Logo
85 people viewed this question
Top Morphy Richards Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Morphy Richards Vacuum Expert? Answer questions, earn points and help others
