Paper not sensing
Epson 9880. load paper message is permanent.
    New Friend:
  • 3 Answers
I think the head of your printer ruined take it to epson agent to repair it
Posted on Oct 13, 2013
  • Amit Sen Oct 13, 2013
    After replacing the head I I'm facing this problem ..
4 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Alarm light on permanently
make sure all compartments are closed
make feed doesnt have a stuck page in it
sometimes if the compartments arent closed right or by some chance the ink cartridge was bumped this will sound the alarm
Posted on May 22, 2008
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
SOURCE: HOW TO LOAD PAPER INTO EPSON SX 100
Hey!! I just had the same problem, was feeling pretty stupid! You've prob already figured it out but just incase any one else is looking for an answer...
When you look into where you're supposed to load the paper there is a grey thing about halfway over. This is the guide. It doesnt tell you properly in the instructions you need to move it but you do. It doesnt slide very easily.. thats why I thought it was just a part of the printer. But if you push it back it'll slide easier. Anyways move this all the way to the left, load your paper then bring it back to the right as close to the paper as you can
Posted on Jul 03, 2009
Paper out when is loaded with paper
The paper tray may be full, but you are calling for paper from the rear feed.
The paper-sensing system may be damaged.
The rollers that pull the paper in may be slippery, and need cleaning.
Nov 24, 2015 | Epson Computers & Internet
I keep getting "Remove Paper" message when there is no paper loaded
One of the sensors in the printer probably has a small piece of paper in front of it or a sensor has gone bad.
Oct 09, 2012 | Epson Stylus Pro 4000 InkJet Printer
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Brother mfc 9880 fax/copier makes grinding noise and has paper jams
Probably a broken Hot Roller gear in the fuser. The fuser is the section in the back, that presses the print between a pair of hot rollers to melt the powdered toner into the paper, making the image permanent. That combination of heat and pressure makes the fuser vulnerable to breakage in any laser printer or copier. The HR (hot roller) gear is a ring around one end of the heated roller, and it sometimes breaks apart.
The MFC 9880 isn't listed on Brother's US service website, so I can't tell you whether you need to buy a whole fuser assembly or just that gear.
Mar 31, 2010 | Brother MFC-8860DN All-In-One Laser...
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
233 people viewed this question
k24674
jasbo
jasbo
