Question about Ovens
The glass door on my Neff microwave/oven keeps shattering the engineer said it is a problem but they will not do anything about it how can I stop this from happening I keep it clean all the time
  • 14 Answers
SOURCE: Outer glass plate
glass was not tempered correctly contact the manufacture or possibly industrial glass products in ambridge pa they make them
Posted on Dec 22, 2007
Krazytech
  • 725 Answers
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Posted on Sep 29, 2008
  • 41 Answers
SOURCE: TKC 8522/2 top oven outer door shattering
the glass would only shatter if it was installed backwards but then it would of shattered a long time ago it shattered due to a scratch on the glass or the door was damaged
Posted on Jan 01, 2009
SOURCE: shattered glass window on oven door
can I install a cooker by a window
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: kitchen aid oven door glass shattered
gget a new door
Posted on Jun 21, 2009
I have a Kuppersbusch microspeed plus (EMWK9600.0M) was in the house when we moved In. whilst using it in microwave mode I heard a bang and the internal glass door has shattered.
The glass will break if the food being heated is not covered and fat/grease heats up to flash point on the glass or there is a cut in the glass or the food banged against the glass or the glass was stressed by an incorrectly fitting door.
A new door is possibly available or glass.
May 17, 2017 | Kuppersbusch Ovens
Microwave door glass replacement
yes u can refit it normally.but do it carefully.need more help regarding this let me know .
Jun 16, 2008 | Ovens
Oven door glass shattered
What was the weather outside?
Feb 03, 2014 | Miele Ovens
My outer glass on door has shatter by its self can it be replace
You should be able to obtain a replacement door glas, they are usually supplied as a seperate item.
Try the following.
WWW.ESPARES.CO.UK/NEFF
WWW.NEFF.CO.UK/CONTACT.HTML
Mar 07, 2010 | Neff B1421 Electric Single Oven
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Outer Glass Microwave window shattered after baking popcorn
doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
