Cefc d33193 when im connecting my 4gb pen drive to laptop im getting this error( Usb device not recognized. one of the device attached to this computer is malfunctioned,and windows does not recognize it. ) what to do...?
    Sergeant:
  • 206 Answers
Often when this happens, the drive was removed without "Safely Remove Hardware" . Try different computers (Operating Systems) and when recognized, Use the "Safely Remove Hardware" key. Then try it on your laptop.
Posted on Oct 15, 2013
bharrie
  • 158 Answers
SOURCE: WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Posted on Jan 16, 2009
kamal1984
  • 1383 Answers
SOURCE: Not recognized by any computer
no it is supported on high speed or usb legacy 2.0
Go to bios setup and setr usb legacy 2.0 high speed
then save settigns
Posted on May 25, 2009
SOURCE: Usb device is not recognized it has malfunctioned i get this msg when i start my computer
Change your USB cable.
Posted on Oct 06, 2009
aviral_srms
  • 1216 Answers
SOURCE: kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Posted on Feb 14, 2010
  • 1584 Answers
SOURCE: My Dane-elec 4GB usb flash drive , no drivers?
Try it in another PC, if the same its a writeoff.
Posted on Mar 09, 2010
Have TRANSCEND D33193 4GB pendrive when i plugged it in my PC it is not detected , some one please help me.........
all pen drives are like jokers of a pack of cards....they behave very funny when you need them....
one of the most stupid inventions of the computer world....are these pen drives....
they are very much likely to carry virus from PC to PC....unlike the CD / DVD that cant be written without using a write program.....like Nero etc....CD/DVD disk are write protected by default....but the USB sticks can be used by drag and drop files.....so the virus get in without the user doing anything....
also when you thingk that you are buying a 4 GB pen drive, some times the dulicate are not exactly 4 GB...they are just 1 GB...and show 4GB as capacity...after using for some time they show their real face(1GB) and the drive becomes useless....
To tell you the fac many mfg are packing more and more space into a pen drive...like 32 GB, etc...but actually the physical capacilty is only 2 GB but expanded to 8 Gb / 12 / 16 GB using a compress program....after few uses....that becomes usless.....
Apr 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Hello , I used my sim (mic d33193) in many computer and got the same message: "USB Device Not Recognized" One of the USB devices attached to this computer has malfunctined, and Windows does...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb pen drive transcend D33193 not recognized problem:
Solution for the problem:
1. The solution is just to "Turn off the computer and unplug it from the power supply" (Unplugging is necessary as today even after turning the system off, the motherboard continues to get power).
2. Let the system remain off for about a minute.
3. Restart the system and wait for it to boot completely before inserting the drive again.
Update:
You can try this solution also. Run devmgmt.msc in the run box. Assuming that the USB is in inserted state, click onScan for Hardware changes under the Action menu. USB should be detected now.
That's it the problem will not appear again.
Jan 07, 2011 | Computers & Internet
My pen drive is not open (mic d33193)
u need to formate your pen drive, with low level formatting.
Jan 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I am having D33193 Transcend Pen drive (1GB). For last few days, due to some problem, computer does not detect it. That means, in my computer/exporer, I am unable to see it. Any solution? Thanks in...
I think you are getting the error message unable to recognizance and having malicious functioned
Please restart the system in safe mode and try to connect the drive and format with command prompt
or try to connect in any other having Linux operating system
Jul 28, 2010 | Electronics - Others
How to repair my pen drive????? when i connect my pen drive with my laptop a message is shown ''not recognized USB Port'' . so, how to start my pen drive? plz rply your answer......
if its in warranty replace it give me ur pen drive details like s/no , etc.... ill help u to get new 1 dont worry now in this state of drive u cannot do any thing its a hardware error the memory ic has been damaged so only option left is company mail me prince2parag@gmail.com for more support visit my site neotechcomputers.co.in
Jul 05, 2010 | Kingston 4GB Secure Digital High Capacity...
Dear Sir, We are using a 4GB Kingston pen drive but this is not open. when we are connect with the computer then some error shown so pls give us some solution to open the pen drive. Error shown: - one of...
in my experience, you need to update drivers, or try another computer..... on one of my co mputers if i open my conputer fast enough i can use the drive, otherwise it will not open.....
Apr 25, 2010 | 2001 Dodge Ram 1500 Truck 2WD
PEN DRIVE NOT OPEN
what problem you are facing with your pen drive? are any error message you are getting when you try to open your pen drive? please send us your problem in details.
Apr 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
