Question about Empire Heating & Cooling
Blower runs all the time empire rh50 - Empire Heating & Cooling
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
It may have a separate switch that you have to manually turn off
Posted on Oct 20, 2013
How to turn on blower motor for a wall furnace empire 35-dv 4lp
Hi Dale. So is there a problem with the fan not coming on at all, like the burner comes on when the thermostat is turned up but the fan doesnt come on? If thats the case then its probably a bad fan switch or bad fan motor.
Jan 16, 2018 | Empire Heating & Cooling
Empire earth 1 not running in windows 8
Empire Earth is not supported on Windows 8, . You will need to manually edit the registry.
You need to open "Run" (can do it by pressing the "Start" keyboard key and then "R"), type "regedit" and then click "Ok".
Navigate to "HKEY_CURRENT_USER\Software\SSSI\Empire Earth\Wait for VSync" and change it to "0" (do this by double clicking the entry).
Then navigate to "HKEY_CURRENT_USER\Software\SSSI\Empire Earth\Rasterizer Name" and change it to "Direct3D Hardware TnL" (similar to how you did with VSync).
Mar 28, 2013 | Sierra Online, Inc. Video Game Consoles &...
Our furnace is less than 1 year old - turned it on the other day the the blower does not work ????
Depending on which model optional blower you have, either one requires that the fan switch be turned ON for it to operate (manually or automatically). Also be sure that the blower cord is plugged into a functional* wall outlet. I have included a link to the Owner's Manual for your model Direct Vent Heater. In case you have misplaced yours. Starting on page 18, you will find the 2 optional blower models.Determine which one you have and follow their suggested recommendations, as one requires oiling several times during the heating season.
http://www.empirezoneheat.com/assets//EHS/manuals/12434--0410%20%28EN,FR,SP%29%20DV-%2825,35%29-2SG.pdf
* "Functional" meaning there is power to that outlet and a circuit breaker has not been tripped.
If you continue to have an unsolvable problem contact Empire Comfort Systems Technical Service Dept 800-851-3153. The blower has a I year warranty. If you have your dated Proof of Purchase, repairs or replacement may be covered.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Empire DV-35 Heater
Blower stopped working Empire Stove Model # RH655 Ser T40891422
Beth, first check the blower's cord to be sure that it's still plugged into the wall outlet. Also, check your home's circuit breaker panel for a tripped circuit breaker, that is feeding that outlet.
On the mechanical side there's 3 things that need to be done:
1. Check the Fan Control by shorting across the terminals.
2. Check for blower wheel binding, by removing the wheel and operating the motor.
3. Check for frozen bearing due to a lack of oil.
To further help you with a parts breakdown, I have included a link to the Owner's Manual for your Model. You can download & print it if you like.
http://www.empirezoneheat.com/assets//EHS/manuals/128
If you continue to have a problem with it , contact Empire Comfort Systems Technical Service @ 800-851-3153.
Sep 16, 2011 | Heating & Cooling
I have a RH-65-1 propane heater. When the heat builds up in heater the blower motor does not come on, it just 'hums.' Please help and advise
it would sound if the blower motor is stuck turn off blower motor try turning by hand see if it moves , or look for a end cap on the motor you could try putting oil in it , or try motor on summer switch see if it runs , if none of this works you could looking at a new motor .
Sep 14, 2011 | Empire Heating & Cooling
Had a problem with the thermostat connected to GW-50-4 Wall furnace. One fan is not working at all, the other fan runs continuously even when the furnace isn't running. Is there a control swith or...
Jake, it sounds like the motor coil wiring on the blower that doesn't work may be damaged or has been disconnected.
Regarding the one that is still running. The automatic fan control is located on the bottom of the blower assembly. The fan control is a nonadjustable, automatic type. The fan control will require between 3 and 7 minutes of main burner operation before the fan control "closes" and activates the blower. The blower will continue to run between 3 and 7 minutes after the main burner shuts off, before the fan control "opens" and deactivates the blower. In which case, if it continues to run and run and run, the fan control switch (part # R-2503) may have failed and will need to be replaced. You can order the part from Empire Comfort Systems Tech Service 800-851-3153. Have the Model Number, Serial Number of the heater handy, as well a the Part Number. when you call.
To help you further, I have included a link to the Owner's Manual for that model wall heater. You can download and print it for future reference.
http://www.empirezoneheat.com/assets//EHS/manuals/GWT-%2825,35%29_Manual.pdf
I hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Empire GWT-50 Wall Mounted Panel Heater
My empire heater wont turn off and just keeps blowing cold air. pilot is lit and all thermostat wires seem to be connected. any ideas?
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Dec 04, 2010 | Empire DV-35 Heater
Crashes when i start EE AoC
DO not worry i have vista but it works for me. you may need more R.A.M or free space or if your not an administrator ask the administrator to allow empire earth AOC cos i had that prob but i fixed it.
Jan 16, 2009 | Empire Earth Expansion: The Art of...
Can ''Age of Empires'' run on a netbook via SD card?
you can if ur advent is running a windows format, if it is a linux based, you will need a linux copy, but yes you can! you have to install the game to the sd card, just like you would to a regular hdd. I have the original warcraft and warcraft 2 on an sd card, that i use with my ASUS mini....www.computereworld.com
Jan 11, 2009 | Computers & Internet
Heating & Cooling Logo
54 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
