It probably says SUD. This is due to too much detergent. Try running the unit empty, on hot, in a rinse/spin cycle, then a normal wash cycle. If that does not fix it, check the drain hose, to be sure it is draining. If that does not fix it, check the filter: take the front panel off, put a bucket in front of the unit, unseat the feet holding the white plug in, pull the white plug out of the unit over the bucket, unscrew the plug and allow to drain, then check the filter, then screw filter back in, push the plug back into the unit, reseat the feet, and replace the panel. Other solutions can be found at:
http://appliancejunk.com/forums/index.php?topic=1785.0
I have done every thing and can not get the sud error gone. (sd) I hope that mean suds
