Question about GT I-Drive 3.0
Replacing the dogbone carbon link on GT 2013 - GT I-Drive 3.0
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Posted on Jun 03, 2015
2013 hyundai tucson will not idle and stalls out.
Check the throttle body bore and plate for carbon buildup. Possible vacuum leak also.
Feb 08, 2016 | 2013 Hyundai Tucson
Cabin filter hylantra gt 2013
Here is a video link . Watch and you will be able to replace it .
https://www.youtube.com/watch?v=5ovV0gGjC50
Aug 14, 2014 | Cars & Trucks
VW Jetta MKIV - G68 sensor replacement - how to lower transmission?
Use a floor jack or trolley jack under the transmission. Also use a block of wood if you have the jack on the transmission's lower pan. You will see that the whole engine and transaxle assembly will tilt down somewhat with the transmission mount removed. If it is not enough to replace the sensors, raise the jack back up and take off that dogbone, then lower the whole thing again until you can get to the sensors. Be careful when getting the mounts back on, that the engine and transaxle settle down perfectly into the mounts, so you have no vibration issues.
May 20, 2014 | 2008 Volkswagen Jetta Wagon
Change default font in word 2013
Click File > Options > General. Change the default font in "When creating new workbooks"
Mar 29, 2014 | Computers & Internet
My Samson Carbon 49 keyboard controller. Under Device Manager/Sound, video and game controllers - DTMB BDA TV USB Properties General, This device cannot start. (Code 10).
1. Go to devices and printers.
2. Double click SAMSON Carbon49 to open
3. Hardware > properties > General > Change settings > Driver > Uninstall.
4. Turn off the device and turn it back on.
5. Hardware > properties > General > Change settings > Driver > Roll back driver.
Should work now
Jan 16, 2014 | Samson Carbon 49 USB/MIDI Keyboard...
Change spark plugs
There's a procedure called "rotating the engine" for GM cars. It pulls the top of engine forward towards the radiator just enough to get to the plugs on the back.
At top of engine, front of car, you see a "dogbone" brace. You probably have two. Running from a bracket on the engine to top of radiator support. remove the long bolt and nut (size 15 mm) from both dogbones. Now on underside of one of the dogbones is a hole, see it? You have to pry or pull engine forward (get help, you need it) enough that the long bolt you removed from end of dogbone goes through the new hole- engine has to roll over forward enough that the new hole now fits into hole on radiator bracket. Shove the long bolt through to hold engine in forward position. Now you can get to the rear plugs-gives you just a little more room.
If this is not clear, post back. Good luck.
Dec 05, 2011 | 2000 Pontiac Bonneville
My car makes a knocking or rattling sound on uneven road surfaces
Check the front suspension for worn or loose componets.
Jul 20, 2011 | 2002 Ford Escape
ERROR >>> C:\Program
what is happening here is that it is unable to create a Readme in the directory. what you need to do is make sure that the program has write permissions set. And also make sure that you have write permissions. This should correct your issue.
Nov 03, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I need Dogbone bearing dimentions
The outside edge of all bearings have a maker and bearing number i.e. "NGK2604". Get the number then go to an industrial bearings company. They can look up the bearing and see if it is in stock and if not, they can look up a matching bearing from a different manufacturer i.e. " SAS3107". The actual dimensions will likely be available at the same location. By the way, most people have no idea what you mean by "dogbone". Do you mean the crankshaft main bearings?
Jun 08, 2009 | 1997 Honda CBR 600 F(3)V
GT I-Drive 3.0 Logo
126 people viewed this question
Top GT Cycling Experts
David Payne
David Payne
ray gallant
dante
Are you a GT Cycling Expert? Answer questions, earn points and help others
