Question about Dryers
Dryer will not keep running
It is an electric dryer. Hotpoint. Checked venting, it's clear. If you press start button, it does start back up. But shuts off shortly. Is it a faulty hi limit?
  • 544 Answers
HI,
if you dryer won't heat?
you do need a new motor.you need to take 2 screws out of top where lint filter goes. take top up and their will be 2 screws one on each side take screws out and pull upward and forward and the front panel will come off. you will need to remove belt and tub then you will see motor. you will need to be able to grab back side of motor that attaches to blower and front shaft of motor and turn opposite way to come loose from blower. you will then take back clip off and front clip and unplug motor and pull out. good luck hope instructions helped.
thanks,
Posted on Apr 23, 2009
Why kenmore dryer won't start?
Most likely you tripped the over heat fuse.
This will happen if your vent hose is clogged or worse inside the machine's plumbing from filter to vent hose.
Look up the electrical diagram and figure out where it is, yours should be in the back of the machine but verofy.
Get a Digital Volt Meter at Harbor Freight $5.00 and measure the OHMs on the fuse, if it fails then you need to replace it but first make sure vent is clear or it will trip again.
Fuse is there to keep from over heating and a fire hazard.
Post your findings,
Jim
Aug 18, 2014 | Kenmore Elite HE4 Electric Dryer
Hotpoint Dryer has burning smell, checked vent--ok,checked screen just inside--ok. Drum turns. Four screws on back with depression space are extremely hot.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 27, 2011 | Hotpoint TDC32 Electric Dryer
My tumble dryer keeps losing heat it still works and i have to keep pressing the button on the back of the machine for it to heat back up
take the vent tube off run dryer, it should not trip your button. You will need to clean the vent tube. Good Luck Tim
Feb 05, 2011 | SNK Knight 43AW Electric Dryer
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Asko T700 overheats and shuts off
replace the timer or temp sensor
Aug 27, 2009 | Asko T721 Electric Dryer
I have a very old roper dryer (11 yrs), it quit mid cycle. It ticks when I set the timer but nothing happens. The on button quit along time ago but when you shut the door it would start. Today nothing...
You've got an open circuit somewhere in the loop betwixt the start button, the "safety" button actuated by the door, and the motor/heat coils. Trace out those circuits and you'll have that thing running in no time.
Feb 27, 2009 | Roper REK2950W Electric Dryer
Hotpoint TDC32 keeps switching off after a short while
Yes, it sounds like the relay is the prob
It is located at the top behind the console panel.
It is a clear plastic covered box about 3" long, and held in place by 2 screws.
Changing this should solve the prob.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
