Question about Thomson Audio Players & Recorders
Although these headphones are working, the volume is very poor
Please solve my laptop sound problem?
Check whether the volume to media level setting. If it is let to extreme low, there will be no audio output, although the system start-up sound can be heard through the headphone.
Jul 08, 2014 | Computers & Internet
Marshall Mg30DFX guitar amp volume level cuts in and out! Anyone know how to fix this or what the problem is?
I have just fixed one of the amplifiers with this fault. It was a poor solder joint on the headphone socket. The ground of the speaker is switched through the headphone socket, so if there isn't a good connection, the speaker volume drops, but the headphone output is still OK.
Nov 03, 2012 | Marshall Music
Shure Srh 240, new headsett I bought and although the sound is good, I cant get the same volume as with my koss headsett, although I'm playing through my phone at the moment. is it has anything to do with...
I have also experienced differing volumes when using different brands of headphones (I have worked as a sound engineer part time in the past.) It's usually due to a difference in impedance between the different speakers using in the headphones (sometimes the impedance will be indicated on the headphones like 16 ohms.) If the two different kinds of headphones have differing impedances, the apparent volumes at the same level settings will be different
Feb 28, 2011 | Shure SRH240 Two Pack with HP4 Headphone...
I have a 50" samsung plasma that was working fine now the volume just dissapeared & when i try to adjust the volume it shows the normal volume display with headphone icon in the display & when i...
You would need to replace the headphone socket then and if I am correct it should be mounted to a plug in board. I first need the model number of your Samsung to look up the part number. The model will be on a sticker on the side and will be something like HTP50***/XAA or something like that.
Sep 02, 2010 | Televison & Video
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Iam using ubuntu 9.04.sound card is not working.I
If you are getting sound through your speakers then the sound system is working. If you lose the sound when using the headphone jack then either the headphone jack is faulty or your headphones are...
Although, rarely, you may find that opening the alsamixer from the terminal will fix the problem as some versions of Ubuntu have a special volume control for the headphone jack....
You will need to open the mixer as the Administrator
Type
su aslamixer
If this helped please vote kindly
Oct 07, 2009 | Canonical Ltd. Ubuntu
How do we increase the volume? On some channels it is loud but others my husband even with his hearing aids has difficulty in hearing?
I'm assuming that you don't have any volume left to raise the level. The fact is, that cable (and satellite) companies are sloppy is setting individual channels close to each other in volume since this is a universal problem although it has long been the practice of ALL of the channels carrying commercials intentionally set the audio levels higher on those than they set for the program material.
My hearing is also shot so I sympathize with your husband's plight.
There are several different brands of wireless headphones available for ~$30-$60 US that have a transmitter (normally infrared) and headphones with a receiver built into them. These will not work through walls but the more costly units use radio frequencies to transmit the signals and these will work through walls.
I suggest you look for reviews by model number on any set that interests you before buying; they aren't all equal. You can see some of them at this eBay link:
Wireless Headphones
Oct 03, 2009 | Televison & Video
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Dec 26, 2008 | Televison & Video
Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Dec 26, 2008 | Hitachi 26HDL52 26 in. LCD Television
19 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
