Question about Brother MFC 420CN All-In-One InkJet Printer
Wont Print I have change all inks and have checked to make sure that the inks are properly put in. I have not been able to print lately and now I am getting this message Unabale to print, See Troubleshooting and rountine maintemance chapter. Any help will be greatly appreciated. Stell
  • 832 Answers
Stell, press menu then start mono (b/w) then 4x arrow-up button. What error code does the machine display?
Posted on Sep 25, 2007
6ya staff
SOURCE:
Won"t print
Canon printer.....won't print.
Well, that can be tough to figure out without some more info. :o)
1. What model of cannon printer, Is it ink jet or laser?
2. What is your computer's operating system? (32 or 64 bit too)
3. Have you installed the drivers for your operating system and made sure they are updated?
4. Have you changed the ink/toner cartridges lately?
5. Have you not printed for a long time? Ink jets especially will get dried up fast if you don't print regularly?
6. If you have the printer drivers installed have you tried uninstalling them and then reinstalling?
Mar 12, 2011 | Canon Office Equipment & Supplies
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson...
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Mar 11, 2011 | Epson PRINTER, 4800 PORTRAIT EDITION...
I've changed the ink cartridge in my epsom printer but it wont print, what can i do
If you haven't printed a lot lately, your print head might clogged. Here's what you can do: go to "print", then "properties", then "maintenance", and find the option "head cleaning". You will hear strange sounds coming from inside your printer, nothing to worry about, the printer is just trying to push the ink through the print head. In the end, the printer will print 4 colors: black, yellow, magenta and cyan. If the colors seem ok to you, you have fixed your problem. If not, repeat the process several times (just bear in mind that cleaning the head uses a lot of ink).
Hope that helps, and if it doesn't, please let me know, would love to help find a solution to your problem!
Mar 05, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Dec 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
On: The printer is ready to print.
Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
Off: An error has occurred and the printer is not ready to print.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
WILL NOT PRINT!!!
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
Ink Tanks:
- BCI-24 Color
- BCI-24 Black
  1. Make sure the power is turned on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover.
  5. Check if the ink tanks are installed properly.
  6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
  7. Close the Inner Cover.
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  9. Press [+] to select [NO] and exit.
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
62 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
