Question about Sharp Televison & Video
Lc 32sa1ea my sharp LC 32SA1EA has started to need
Lc 32sa1ea my sharp LC 32SA1EA has started to need time to warm up - it used to come on fairly quickly i.e. a few seconds, but now it looks broken for about 5 minutes until it warms up, and then it suddenly comes on and is normal. What I mean when I say it looks broken for 5 minutes, is that there are coloured vertical lines on the screen or just a weird hazey screen which clears from the left until it is all black. I imagine there's something that used to help it warm up quickly that is dead now. Thanks Noel
SOURCE: vertical hold problem
Maybe sync separator transistor is faulty
Posted on Jan 08, 2008
  • 2326 Answers
SOURCE: 33 inch Panasonic gaoo bought in 95 picture trble
Check for leaky capacitors in the vertical section of the TV or cold solder joints.
I would also check in the power supply.
Good Luck.
Posted on Jan 16, 2008
  • 395 Answers
SOURCE: 56" DLP Turns on for just a few seconds, then off with the dreaded 3 lights
maybe, but I would replace the lamp first. the system looks at current draw from the lamp if it is too high it will shut down. these lamps are hard to detemine weakness by physical appearance. they are gas under presure. if after replacing the lamp the unit still has this problem then the balast. I have also seen the DMD board cause this problem. but the lamp is the most likley problem.
Posted on Feb 08, 2008
bestdarngood
  • 3037 Answers
SOURCE: sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where your problem is coming from but most likely it will be the power supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c flipping off and on and current demand being peeked from the utilities storms or quick power loss off and on can cause problems like this to occur
Please let me know if you have any other questions, thanks
Posted on May 14, 2008
  • 35 Answers
SOURCE: Can only see half the screen
all right you have a system error call xbox at 1-800-4my-xbox and tell them and send it in for reparis it takes two to three weeks not that bad free shping and if they can not fix your xbox they will give you a new one. i hope i helped you my email is tootles100@yahoo.com
Posted on Jun 15, 2008
Sharp lc-60le650u blink codes
Different model number in the link below but I would assume they're the same fault.
(D_POW. Digital 3.3V failure. Power failure details (Flashes slowly twice and flashes fast 3 times. > DET_D3V3(36pin) failure (L). Digital 3.3V is not applied. If error is detected during start-up or operation, the power is turned on again by polling.)
Electro help SHARP LC 40LE810UN LC46LE810UN LC52LE810UN LC60LE810UN HOW TO...
Apr 02, 2014 | Sharp Televison & Video
LC-65D93U Sharp LCD not powering up just the blue light blinking
Our experience solving this was fairly long and I hope FixYa will excuse me for posting a link to it rather than copying all of it.
It's a free share of our experience and some hints on troubleshooting Sharp LC-65D93U with blinking power LED.
Of course your problem may be different, but the know-how we gained and share should still be of help in your quest:
http://blog.coppelltvrepair.com/2014/06/sharp-lc-65d93u-blinking-blue-led.html
Hope it helps!
Jul 05, 2011 | Sharp LC-65D93U Television
I get a large black rectangle covering 1/3 of my
I have a similar problem using an older 20" flat screen standard definition TV. (not High Def). I can see a little of the picture but more than 2/3 is covered by the black. My model is LC-20SH7U.
I used sharpusa.com "contact us" section.
Hopefully I get some kind of reply to report what they say.
May 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
AUDIO/CLOCK
for your sound try to program again .if it doesn't works, speakers problems , audio amplifier problem which can be done by a professional
Sep 12, 2009 | Televison & Video
LC-32D6U GETTING NO SOUND
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (rubbing alcohol works quite well). Despite what the images say,
YOU MUST REMOVE ALL BLACK RESIDUE FROM BOARD. IT WILL NOT WORK IF ALL THE RESIDUE IS NOT REMOVED.
This kit is Sharp Part Number: PSPKIT663WJZZ and is available from Partstore.com for $19.95. http://www.partstore.com/Part/Sharp/Sharp/PSPKIT663WJZZ/New.aspx
It’s possible to get the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. http://www.partstore.com/PartSearch.aspx?PartNumber=PSPAZA663WJKZ&hiddenInputToUpdateATBuffer_CommonToolkitScripts=1&x=26&y=14
Jun 21, 2009 | Sharp LC-26D4U 26 in. LCD Television
Xbox and tv = no sound
Yes, those cables are quite common. Check any electronics retailer like Best Buy or Walmart.
Aug 25, 2008 | Microsoft Xbox 360 Console
Jun 07, 2008 | Microsoft Xbox 360 Console
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
