Question about Cakewalk Music Creator 4
I can only record two tracks at a time. I want to record four. I have a fast track ultra with USB 2.0 and Music Creator 4. When I select drivers from the options menu only one driver will stay selected at a time. I need both 1/2 amd 3/4 highlighted at the same time. Please help.
I want ot install acrobat distiller
Posted on Apr 24, 2009
Can i attach backup device to my lg HT356SD?
I would say yes, from what the manual says, the LG HT356SD has some Unique Features:
#1 Portable In : Listens to music from your portable device.
(MP3, Notebook, etc)
#2 USB Direct Recording : Records music from CD to your USB device.
Read the manual, on page 26 it will show you how to do it, I found it at www.theatresystem-manual.com under lg, or go directly to the link I provided.
http://www.theatresystem-manual.com/manuals/lg/LG_HT356SD.pdf
Recording to USB
1. Connect the USB device to the unit.
2. Select a DVD/ CD function by pressing
FUNCTION.
One track recording - You can record to USB after
playing the file you want.
All tracks recording - You can record to USB after
stop.
Program list recording - After showing the
programmed list, you can record it to USB.
3. Start the recording by pressing X REC.
4. To stop recording, press Z STOP.
Mar 18, 2014 | LG LHT854 Theater System
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Nov 29, 2010 | ION Audio TTUSB10 Turntable
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
Hi folks, my problem is when rec. audio the tracks start to bleed onto next track and my fx do the same thing.i'm a 20 yr. musician with a month of cakewalk time a.k.a.(novice) please help. in dire straits...
hi mate no worries heres a fix for ya lol in music creator 4 go to transport then click on recording options in the lower part titled "loop recording" click store takes in a single track you done no more bleeding i know that really sux
Oct 25, 2009 | Cakewalk Music Creator 4
Can't record vocals
You can use any mic you want but you have to go to the soundcard mixer and enable the source for recording from the recording properties. If you have a separate soundcard not the onboard one usually it will have it`s own mixer software so you open that up and set it to record from the microphone input if that`s where your mic is inserted. If you use the onboard sound card then go to control panel - sound and select the device you want and also set the recording source. In sonar you have to right click on the track in the left part of the screen. This brings up the properties for that track. The you select the sound card input and output for that audio track.
That shoudl solve your problem.
Of course you will get a much better result if you use a good mic plugged into a mixer or pre amp and send the source into the line in of your sound card and adjust the rest accordingly.
May 14, 2009 | Cakewalk Music Creator 4
Cannot make mp3 files from cds
Don't bother using Roxio for this - use Windows Media Player 11.
1. Open Windows Media Player
2. Run the mouse over the "Rip" tab - a small aroow should appear underneath the word "Rip" - click on the arrow and a drop-down should appear.
3. Select - "Format" - change to "mp3"
4. Now insert your CD and press the Rip button - by default, Windows Media Player will store the mp3 files in the My Documents --> My Music folder
Now use Roxio to make a CD out of the Mp3 files
-Tha Mp3 Doctor
Mar 20, 2009 | Roxio Easy CD & DVD Creator 6...
Playback is way off tempo
I had similar problem, mine played it back slower and lower pitched. http://www.cakewalk.com/Support/newfaq.asp#10
number 10 and 11 fixed my problem, hopefully it will help.
Jan 07, 2009 | Cakewalk Music Creator 4
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Cakewalk Music Creator 4 Logo
138 people viewed this question
Top Cakewalk Computers & Internet Experts
Dan Shibata
Dan Shibata
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
