Question about Asrock G41MVS2 Core 2 QuadIntel G41DDR2A_V_LmATX Motherboard G41MVS2
Asrock g41 mother board memeory slot fault than how can ractifiy this problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Asrock Master
  • 2,226 Answers
Get new board
Posted on May 22, 2014
    Sergeant:
  • 369 Answers
If you have 2 Ram installed
check wether they are install in there perfect order
populate them according to the numbers on the Mother board beside the Ram slots .
try one one ram
if it is a Xeon processor you have to use in balance .
if you put the ram s in a proper slot and listen for the notch lock sound .
it should be firmly placed.
And then try to boot now and should be all fine.
Posted on Jul 12, 2014
  • 883 Answers
SOURCE: shareing virtul memory
there should be no virtual memory limitation on a motherboard. That limit is a windows only setting that is controlled through the control panel and limited physically by the hard drive. Perhaps you mean to say video memory? ...or conventional memory?...or which other?
Posted on Jun 09, 2007
Dipu007
  • 2110 Answers
SOURCE: I want to connect another
No u cant use that port....if u want to connect then u have to buy a PCI to IDE convertor...
Posted on Dec 07, 2008
SOURCE: Reset A Bios of Asrock mother board
go to the following site
http://www.asrock.com/mb/manual.asp?Model=K7S41GX&s=462
download the user manual(not quick installation guide) and check page no 7 or content 1.3 to get the jumper pins to reset the motherboard.
just short those pins and the cmos settings will be gone.
another simple method is just remove the battery and wait for 5 min and again plugin the battery.
thats it you motherboard is resetted to factory settings.
Posted on Apr 22, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: I want to upgrade my cpu for this mother board
Here is a link for your mobo
http://www.asrock.com/MB/overview.asp?Model=P4VM800
looks like you can use any intel processor as long as its a socket478 by intel
Check out nvidia agp cards at www.nvidia.com You can get a 512mb card agp.
The bios is plug and play which should not be a problem.
You may need to upgrade the memory also.
Posted on Mar 22, 2011
  • 2226 Answers
SOURCE: does the mother board Asrock 845GV (P4I45GV) support pci sata card
when installing it ask you for sata driver disk when startup is copying files you need to hit f6 key to get them loaded from a drive thats all you need to do.ok jim
Posted on Nov 22, 2011
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
I have a ASROCK G31 945 intel MOther board , When i purchased i fiited with IDE CD/DVD Drive . INow is it possible to connect the SATA CD/DVD drive to my mother board. i have SATA connector on my MB ....
You need is an open slot for the drive, an available SATA slot / cord, and a SATA power. It may require you to go into BIOS, and in some cases a driver for the new drive. Don't forget the SATA drivers if you have XP.
GL
Oct 08, 2012 | Intel ASRock G31M-S M/board - Intel...
I have asrock alive nf7 board, my problem is the pcie slot and ide slot in mother board. the board is damage.?
hi can you pls specify what is the problem of your pcie and ide slot? so that i can help you?
Jun 01, 2011 | Computers & Internet
I want to upgrade my cpu for this mother board from 1.8 ghz to 2.8 ghz. What cpu should I go with. Am I going to run into problems with the bios or anything else. Also need to know if I can upgrade...
Mar 22, 2011 | Asrock P4VM800 Motherboard
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
Drivers
driver de audio fsb 800 ddr 400
May 01, 2008 | Asrock 775Dual-880 Pro Motherboard
RE: mother board not going on
Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
The decription (In you're manual), refering to you're memory can be confusing.
You're manual says you can use up to 1GB of
PC3200 DDR400MHz only in Slot 1.
If you add DDR400MHz into slot 2. The board will not support it. (weird)!
If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
Need you're manual? Download it from this link. Click on it.
http://www.asrock.com/mb/manual.asp?Model=775VM800
Asrock's home page for you're 775VM800 board.
http://www.asrock.com/mb/overview.asp?Model=775VM800
Mike
Apr 28, 2008 | Asrock 775VM800 Motherboard
Asrock Motherboard
is there any problems?? do u try any AGP card before or u wont the best card that match Asrock .... if that what u need u can use any nVIDIA cards ... avoid the DDR2 cards ....
Jul 31, 2007 | Asrock (775Dual-VSTA) Motherboard
Shareing virtul memory
Jun 09, 2007 | Asrock P4I45GV R5 Motherboard
Asrock G41MVS2 Core 2 QuadIntel G41DDR2A_V_LmATX Motherboard G41MVS2 Logo
93 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
