Question about Asrock G41MVS3 Motherboard
Memory power beep - Asrock G41MVS3 Motherboard
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Check ram slots. one at the time.
1ram--boot 2ram--boot and so on
Posted on Oct 24, 2013
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
I have a dell inspiron 545. I lost my display and the computer now beeps four times, pauses and beeps four more times. Can you tell me what happened to my computer?
This is normally a memory error. Turn off the computer, and open the side of the case. Pull and re-seat all memory chips. Turn power on, if it still beeps. Turn off power, pull all the memory chips and re-seat one only. Turn on power if it beeps againg, pull the chip out and try the other one. Repeat for all chips. If you find any that do not cause the beep issue, you have found your bad memory chip. If not, try the same one at a time memory test in a different slot on the computer. If no beeps, then its a bad slot and dont use that memory slot.
If none of this works; as unlikely as it seems you could have all bad memory chips, or a bad mother board.
Jun 12, 2012 | Dell Computers & Internet
Dell inspiron has no display and beeps four times and then pauses and beeps four more times
Hi My compuer won't boot up it has a msi km2m motherboard I heard 1 beep I changed the power supply and made sure the ddr was seated and tight now i get no beeps but does not display anything on the...
Do this, first disconnect your memory into motherboard slot and then power on your PC. if you hear repeated beeping means no memory installed, the motherboard work fine. try to insert again your memory. if your memory are two pcs. insert only one memory and then power on again your PC. (only one by one insert memory for testing so you can trace if one of your memory was defective).
Try this,
Motherboard beeping troubleshooting guide.
(Note: before touching computer parts like motherboard, memory, video card and specially hardisk the very important parts of PC. discharge your static electric into floor ground or the case of your power supply. need also external PC speaker. if no onboard PC speaker ).
No beeps means short circuit, no power, bad processor, open parts or defective parts specially capacitor parts.
See this sample picture of capacitor leakage and defective.
One beep means everything is normal the motherboard work fine.
Two beeps means cmos bios error and defective.
One long beep, one short beep means motherboard need tracing defective parts specially capacitor.
One long beep,two short beeps means videocard problem need tracing of parts CPU and blower fan for working good, also capacitor parts for leakages.
Three long beeps means keyboard error some key press stock up or modules parts defective.
Repeated long beeps means memory not detected, loose of defective
Continuous Hi-Lo beeps means CPU overheat or loose blower fan with heatsink into motherboard chassis.
Try this solution for your motherboard troubleshooting solutions.
Hope this information can help you.
Thanks for using fixya
Aug 12, 2011 | MSI KM2MCOMBOL-6738-010 Motherboard
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
My serial and password will not register my dvdxcopy
Check
1 Beep
2 Beeps
3 Beeps
4 Beeps
5 Beeps
6 Beeps
7 Beeps
8 Beeps
9 Beeps
10 Beeps
11 Beeps
Continuous Beeping
Oct 28, 2007 | 321studios DVD X Copy Platinum (200000)...
Asrock G41MVS3 Motherboard Logo
26 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
