Question about Acer TravelMate Computers & Internet
Start xp in dos mode
My laptop starts up passes the XP stage and then stays on blue screen, the mouse is visible only.
    Sergeant:
  • 324 Answers
Try to boot to safe mode and try a system restore if that fails then do a repair installation using the windows xp disc
Posted on Oct 17, 2013
TheTechGuy
SOURCE: acer notebook 3002
I would try plugging an external keyboard or mouse in to see if that works. If it does, either the keyboard/mouse (2 in 1 on laptops) drivers are invalid in which case you can go to http://support.acer.com and download the keyboard/mouse drivers and/or utility. Otherwise, most likely the keyboard/mouse hardware is the porblem. In which case either the cable connecting it to the rest of the laptop is loose or more likely the entire keyboard/mouse device is fried. I suggest contacting the manufacturer (Acer) and if your laptop is still under warranty get them to replace it; if not buy it. -The Tech Guy
Posted on Apr 15, 2007
  • 317 Answers
SOURCE: Black screen.
After it appears that the computer is on, shine a flashlight on the screen. If you can see a very faint image, you need a new backlight. If you have no image at all, you need an inverter. More likely than not, it's the inverter because backlights last a really long time.
Posted on Aug 12, 2007
  • 13433 Answers
SOURCE: OS load failure.
The bluescreen saying about the ACPI, I had the same problem at work with a older computer. Next time you get the bluescreen read everything it says.
It tells you to press a button, I'm not sure thats why I'm telling you to read the bluescreen (windows 2000 or xp) it was f5 or f8.
You press f5 or f8 I think it was f5 since f6 is to load custom drivers.
So you press f5 when it asks you to press f6 This disables the ACPI subsystem in the setup and you should be able to install windows 2000 without any more problems. If its not f5 read the bluescreen thats where I got it!
Good luck, keep me posted and tell me if theres anything else.
Posted on Feb 23, 2008
pankaj_dic
  • 1250 Answers
SOURCE: My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Posted on Nov 06, 2008
  • 53 Answers
SOURCE: Inadvertantly deleted ''i8042prt.sys''; keyboard & mouse don't work
if you dont have the disc then you just have to download linux unubuntu. its free googel for it
Posted on Jun 17, 2009
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Windows xp tries to start in safe mode screen then as program starts gets brief blue screen then back to safe mode start selection screen once again this keeps repeating
your system will do this as it has shut itself down to protect itself, to make the blue screen stay on so you can write down the error code (e.g stop 0x0000007B),you need to choose the option of `disable automatic restart on sytem failure` (this will be on safe mode screen, reboot, then when you get the B.S.O.D it will stay on and display an error code, google it and you get the answer or post the code on here and i`ll tell you
Jan 14, 2010 | Dell Latitude D800 Notebook
I have a presario 2500 laptop and it will start go to the windows xp loading screen then will go to a blue screen with just the windows xp logo and cant do anything after that but move my mouse
click f5 before xp starts to load. choose halt on error and record code. google that code. most often it is a bios error after a new install (memory...etc.) sometimes you can boot into safe mode to undo a recent change. if all else fails reinstall...could be bad hard drive boot sector also.....check code first
Aug 04, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Gives me a black screen after starting
in this mode u must see a command window like dos window but throught wondows xp otherwise if this not happened ur windows is broken
Jul 26, 2009 | Acer Computers & Internet
Acer Extensa 4630z won't reformate
Yes it is nothing to do with hardware problem of yours, here is a tip to install your windows xp on your ACER Extensa, but before that I tell you that your hard drive inside is Sata so this is the solution, go to your BIOS Setup and change the setting of your hard disk from SATA mode to IDE Mode, find it their., and have your installation with your new windows xp, trust me, good luck!
Jul 26, 2009 | Computers & Internet
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Nov 05, 2008 | HP Pavilion dv4000 Notebook
Unable to start in Safe Mode with Command Prompt in XP Media Center 2005
Hi there. My name is Alex and I am here to help solve this problem
Depending if the BIOS has legacy USB support for keyboard and mouse enabled, you should be able to run safe mode by pressing F8 before the computer boots into windows. I would not recommend going into the BIOS if you do not have much knowledge to the computer as one wrong configuration could cause some behaviour problems or even damage to the pc's components
I recommend connecting a keyboard and mouse that have cable and the PS/2 connectors (purple and green) which can be found at back of the computer at the top. Then restart your computer, hold down F8 and you will be able to run safe mode. The mouse and keyboard will then work
Keep both the keyboard and mouse plugged in and boot windows. When you get into windows, plug in the USB keyboard and mouse into a USB slot and wait whilst it detects it. After a couple of minutes you should be able to use your USB mouse and keyboard and take out the PS/2 keyboard and mouse
I hope this has helped. Please let me know if you have any questions or need further assistance.
Oct 03, 2008 | Microsoft Windows XP Media Center Edition...
Im trying to install win xp on a used computer
Are you useing the windows xp cd?
Enter the xp setup when asked "press any key to start from cd.." (press a key here so you get into the blue windows installer)
And follow the steps, do you get problems there?
Jun 05, 2008 | E-Machines eMachines Desktop PC
Blank screen with cursor
MS-DOS edit command help This would bring up a blank edit screen, as long as the file is saved upon exit
Click on the above link , Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
