Computers & Internet Logo
m
milos damjanovic Posted on Oct 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a motherboard foxconn 45cmx-45gmx-45cmx-k,Will this processor Intel Pentium D 945 3.4 GHz 4M 800 Dual Core LGA775 CPU work on it?
Rajendra Singh
Level 3:
  • Master 394 Answers
  • Posted on Oct 12, 2013
Rajendra Singh
Master
Level 3:
Answers
394
Questions
0
Helped
96332
Points
1264
Yes ,this foxconn motherboard will support the above mentioned
processer. Please check the below link.
Foxconn
Thanks for using Fixya.
Testimonial: "but this site says it has 2 mb L2 cashe,a processor that has 4 L2 cashe.it is the same procesor?"
  • 1 more comment
  • milos damjanovic
    milos damjanovic Oct 12, 2013
    http://ark.intel.com/products/27520/Inte...
  • Rajendra Singh
    Rajendra Singh Oct 13, 2013
    Motherboard supporting processor depend upon the socket number
  • Rajendra Singh
    Whatever cache processer has it will support for the same socket number.
45CMX/45GMX/45CMX-K I do not know what video cards and processors are compatible with this motherboard as I want to upgrade my pc
Hello download the manual here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000341
Intel Core 2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775)
- 1333(oc*)/1066/800/533 MHz (FSB)
- Dual Channel DDR2 667/533/400 x 2 DIMMs, Max. 4GB
- 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
- ATA x 1, SATA II x 4
- 5.1 channel Audio
- 10/100M LAN
- 8 USB 2.0 ports
Good luck
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
2helpful
4answers
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
1helpful
3answers
Can I Use A Intel Pentium D 945 3.4GHz/4M/800 Dual Core SL9QB On This Motherboard
The specification for this motherboard can be found here:
http://www.foxconnchannel.com/en-us/product/motherboards/detail_overview.aspx?id=en-gb0000173
It says it can support 800MHZ or 533MHz Front-side bus Intel chips with socket 755
The specification for Intel Pentium D SL9QB is here:
http://ark.intel.com/Product.aspx?id=27520
It says this is a socket 775 CPU with an 800MHz bus so yes, this motherboard should work fine with this CPU.
Please rate my answer if this helps,
Many thanks,
Chris
2helpful
2answers
Hello can someone tell me if this processor is compatible with this motherboard? P45AL foxconn and processor PENTIUM D 945 SL9QB SL9QQ 3.4 GHz 4M LGA775 Dual Core also if this is not compatible do you...
Yes the board has an LGA775 Socket, which means the processor will suit the board you have.
If you are after cheap processors, ebay is great for used cheap processors.
Let me know if you need further help.
Cheers,
Dave
Is DG41RQ mother board suitable for present Intel Pentium D Dual Core processor E 800 with 3.4 MHz, and Socket LGA775. The name of the processsor is costerica and its bus speed is 800. Model says 945XL...
Yes this motherboard will definitely work with that processor , since this one can support up to a Quad core processor. <br />Here is the complete details specs for this motherboard.<br /><a href="http://www.technology.am/intel-dg41rq-motherboard-233414.html">http://www.technology.am/intel-dg41rq-motherboard-233414.html</a><br /><br />
1helpful
2answers
Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
Support
ecs_buttom_03.gif LGA775 socket for latest Intel® Core™ 2 Duo / Pentium® Dual Core/ Pentium® D / Pentium® 4 / Celeron 4xx series/ Celeron® D processor ecs_buttom_03.gif FSB 1066/800/533 MHz
The above information was taken from their website.
Grand Canyon Tech
Grand Canyon Tech
