Question about Philips 7P6041W TV
Loud pop and picture is no longer available.....
Blown resistor (42ohm) replaced this and it imediately blew the new resistor any ideas?????? for what to look at????- Philips 7P6041W TV. power light comes on then immediately dims to nothing.....
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Blown resistor (42ohm) replaced this and it imediately blew it clearly shows that there is a short circuit in your tv. if you are a tech person please proceed as follows. 1 isolate power supply from hor.output section. 2 now check power supply section.i.e. switching tran., cap..diode etc. 3 if it becomes ok check power supply output. 4 if output is ok then check hor. output section.i.e. h.out tr.,cap& diode in eht winding. 5 check print near eht. 6 at finally eht. 7 see every thing is normal now. now reconnect power to hor.section. put on tv. good luck.
Posted on Sep 25, 2007
R5 Resistor blown. Cannot find specs, or where to
U still can make out the resistor colors codes?Tries websites like Ebay.com,Amazon.com or might just go down to Radio Shack,have that toterance of that resistor to buy.
Jul 21, 2010 | Philips 47PFL7403D 47 in. LCD TV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture pulsing, tv turns off and on
Sounds like a power supply problem, If you are competent with electronics, you may find some blown capacitors or resistors on the power supply board. Equally you can probably buy a new power supply board.
WARNING: the power supply board contains lethal voltages even when switched off and unplugged. If you are unsure what you are doing take it to a repair shop.
Apr 05, 2010 | Philips Televison & Video
Power light blinks - and now the TV won't come on
Most likely the power supply and/or related circuitry has failed.
Charlie
Aug 23, 2009 | Philips Magnavox 27MS343S 27" TV
No power no picture no sound
You have a shorted power component. Probably either the voltage regulator or the Horiz. output transistor. Both will be mounted to a heat siink of some type. The Horiz. power circuits along with the flyback transformer power up 90% of most TV sets.
Geno
Feb 16, 2008 | Televison & Video
Fuse blown
ok well i would check for a open diode in the main ac to dc power supply then check all resistors that look lick they may be low ohms but high watt check to see if you might have a open pico fuse from primary power supply to the regulator check and see if you have stand by voltage this would be easily checked on the power off oan on button get back to me k
Nov 01, 2007 | RCA F32450 32" TV
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
