Question about Campbell Hausfeld 26 - Gallon Air Compressor
Need wiring diagram with color codes
I have a Campbell Hausfeld Model # EX 703800AJ and the number on the motor is 8-176061-01. Problem, friend moved the wiring to move to higher output and now it is screwed up. Need to move wiring back to original diagram. Number 1-6 with color codes for this dummy. Can anybody help with this. Thanks a million Doug
  • 4 more comments
  • darren66 May 04, 2009
    the eletric motor is set up for 115v i want to set mines at 230v need diagram its a century motor
  • kaatsd May 26, 2009
    Bat1956
    Thanks for the response. The wiring diagram is indeed on the inside plate but is very non dersript on how to get unit back to original wiring set up.
  • kaatsd May 27, 2009
    the wires are located behind the shield and are all slip ons and color coded.
    Thanks
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Are the terminals in a cavity in the end shield? Wires on flag terminals? (slip-ons)
  • Bruce Volkers
    Terminal diagrams are always on the motor someplace. Either inside the wiring cover, or on the motor ID plate.
  • Firdous Jan 13, 2012
    Hi kaatsd
    Having the exact same problem, did you find any solution, please let me know
5 Suggested Answers
rayname
  • 70 Answers
SOURCE: Campbell Hausfeld Air Compressor won't start
try turning the switch off for 5 minutes the turn it back on there is usually a circuit breaker or thermal overload that can trip let me know if problem still exists
Posted on Jan 09, 2009
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
nampaboat
  • 150 Answers
SOURCE: My Campbell Hausfeld compressor model
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Posted on Feb 06, 2011
Where to find replacement carbon brushes Campbell Hausfeld pressure washer pw1350
Parts for Campbell Hausfeld can be found at www.chpower.com. Campbell Hausfeld does not however, sell motor parts for many of their tools. You would have to call their 800 number and speak with a parts person to determine availability. You may be able to purchase a close match at a local True Value hardware store. They sell a variety of brushes for many major brands of tools. Purchase a slightly larger set of brushes and sand them to size. If the connector is different, cut off the old connector and solder it to the new brush.
Dec 15, 2011 | Campbell Hausfeld Garden
Product - Campbell Hausfeld TL1017 Butterfly Impact wrench I need a set of plastic valves. Where can these be purchased?
1-800-444-3353. This number is in the manual should you need some technical advice. I'd give them a call and see if they will mail you what you need. Can't find you a rebuild kit out on the net.
Sep 18, 2011 | Campbell Hausfeld TL1017 3/8" Butterfly...
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Air compressor wont turn off
If the wires werent put back right the unit would not run at all , you may have to replace pressure switch when it broke it may be keeping the contacts in the closed position.
Jul 16, 2009 | Campbell Hausfeld 20 - Gallon Air...
Help! air compressor trouble.
ASSUMING YOU ARE TALKING ABOUT THE PRESSURE SWITCH. YOU SHOULD EITHER HAVE 2 WIRES OR 4 WIRES ON THE SWITCH. THE SWITCH IS TYPICALLY MARKED LINE-LINE-LOAD-LOAD. IF YOU CAN SEE THE INSIDE OF THE SWITCH YOU WILL SEE THE CONTACT POINTS. ONE CORD WIRE CONNECTS AND PASSES THRU ONE SET OF POINTS TO ONE WIRE OF THE MOTOR. THE OTHER CORD WIRE PASSES THRU THE OTHER SET OF POINTS AND CONNECTS TO OTHER MOTOR WIRE. YOU TYPICALLY WILL NOT HURT THE COMPRESSOR BY HAVING THIS WIRING INCORRECT - PROBABLY JUST POP THE BREAKER INSTANTLY. IF YOU CANT SEE THE PATH THRU THE POINTS YOU CAN OHM THRU THE POINTS AND GET A CONTINUITY BEEP ON A VOLTMETER. IF THATS NOT AN OPTION, JUST SWITCH THEM AROUND UNTIL IT RUNS. HOPE YOU BOUGHT THE SAME CUT-IN AND CUT-OUT PSI. GOOD LUCK AND WRITE BACK IF THIS DOESNT GET IT. JODY
Apr 05, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air compressor head gasket diagram
Campbell hausfeld has all their manuals on line at www.chpower.com / you can enter the model # of the whole unit or just the # of the pump. Also you can enter just a partial number example wl650 for a list of models is that range. Use caution when installing gaskets for chpower oiless pumps. Some of their gaskets are very brittle. After installing parts, turn pump by hand to make sure all parts are in their proper place and that there is suction. Enjoy
Dec 02, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
581 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
