Question about Adapters.com ETHERNET PLANET| PCI WL-8313 (WL8313)
Driver win 7 64 - Adapters.com ETHERNET PLANET| PCI WL-8313 (WL8313)
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Polaroid PMP 120-4 driver
THere are drivers for Windows Server 2008, Windows Home Server, Win 64-bit, Windows Server 2003, Windows Vista, Win Server 2003, Win Me, Windows XP, Win Server 2008 R2, Windows 98, Windows 98 SE
I'm not sure if theres is a drivers for Win 7 or Win 8 so if you don't have one you should install Windows Vista or XP driver using compatibility mode
Dec 06, 2013 | Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital...
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
Apr 08, 2013 | ASUS K42F A1 Notebook
Gateway mx 6421 win764 driver issues
You could, drivers are based on manufacture. Like Realtek is a common maker of audio chips, and sometimes distributors use a popular motherboard.
You may have plateaued at Vista, by try the Troubleshooting Compatibility with Vista 64 drivers before you roll it back.
BTW - This happened to me with Win 8.
Oct 26, 2012 | Gateway MX6421 Notebook
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
I am looking samsung driver for my monitor , model no is sync master 591s , from where i can get this driver , if you have solution for this kindly mail us at vedashealth@gmail.com.
you candownload the driver from www.topdownloads.net
Supported Operating System: Win 95A, Win 95B, Win 98, Win 98SE, Win ME,Win 2K, Win XP, Win Server 2K3
Nov 29, 2010 | Computers & Internet
How do I open/download the user manual for SAMSUNG SCX-3205 printer. When I click on user manual only the front page opens.
Just click:
Print Driver (Including Smart Panel) - Win 2000/XP/2003/Vista/2008/Win 7(32,64bit)
Scan Driver - Win 2000/XP/2003/Vista/2008/Win 7(32,64bit)
Universal Print Driver - Win 2000/XP/2003/Vista/2008/Win 7(32,64bit)
Cheers!
Nov 07, 2010 | Office Equipment & Supplies
Hawking HWU8DD Vista Driver crashing Win 7. I just purchased new desktop running Win 7. Old system ran on XP. XP Driver would not work. Installed XP driver. System runs for ~10 minutes and crashes...
there will be no win 7 driver as win 7 is no longer supported by Microsoft
to get a driver , you have to go to the manufacturers web site , find a down load for that model that is compatible for win 7 operating system
win xp is also not supported by Microsoft so there will be driver problems there as well
Dec 18, 2017 | Hawking Hi-Gain Wireless-G (HWU8DD)
Adapters.com ETHERNET PLANET| PCI WL-8313 (WL8313) Logo
23 people viewed this question
Top Adapters.com Computers & Internet Experts
JP Services
JP Services
Jeff richtman
Jeff richtman
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
