Question about Fuji FinePix S7000 Digital Camera
FujiFilm S7000 ac adapter not working
When I plug in a ac adapter, camera doesn't work.
I checked the voltage on adapter and it's at 5 volts dc, camera doesn't work with or with out batteries when adapter cable is plugged in.
If camera is on under battery power, screen goes blank when I try to switch to ac adapter, when I remove cable, I have to switch camera off to reset. It's almost like a fuse has blown in adapter circuit inside camera
any ideas?
  • todd bailey Apr 23, 2009
    if there is one, I guess I'll have to see if I can open and check wiring
  • 538 Answers
Yes, it is sounds like a fuse(s).
Posted on Apr 23, 2009
  • pontelemon
    pontelemon Apr 24, 2009
    Yes, there is one that takes care of USB. It's very very small SMT tipe.
DC to AC power cord Do they still make them if so under what name or product name?
"DC to AC" cords are not really a common item. They are called "Inverters". Typical inverters are 12VDC to 120VAC and are found in mobile applications to operate houshold current type (120VAC) devices. Inverters cost many times more than thier "AC to DC" or "AC to AC" sisters.
An "AC to DC" and "AC to AC" cord however, is a very common item. They are usually called simply "AC Adapters" and are sold in many electronics stores (Best Buy, Fry's, etc.) and electronic specialty stores (Radio Shack) and electrnics suppliers (MCM, etc.) Nearly all of them are designed to reduce the voltage in your home (120 VAC volts alternating current) to a different but usually lower voltage that is either AC or DC.
In order to select the proper AC adapter, you need to know:
(1) Input Voltage - this is the outlet voltage - often 120 volts in N. America, (2) Output voltage - this is the voltage the device needs and is often indicated near the jack, The adapted must match this voltage. (3) the device voltage type - this will be either AC or DC. The adapter must match the type as they are NOT interchangeable. (4) the size and type plug on the cord that will allow it to mate properly with the jack. There are many, many types and it should be tested for fit prior to plugging in and must match the device jack (5) the power requirements - this is usually shown as a number in Watts (w) and / or Amps (a). It is very important that the apdapter power rating is equal to or greater than the amount specified by the device. Failure to meet the requirements above can cause failure of the device, adapter or both.
I hope this helps and good luck!
Feb 08, 2013 | Uniden BC60XLT-1 Handheld Scanner
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Dragonhawk tattoo gun
Not really my area of expertise.
But I bet I'm more qualified than most people.
(Mechanic, machinist, fabricator, welder, computer geek, etc)
Looking at the Dragonhawk Tattoo Gun shown in this example,
http://www.amazon.com/DragonHawk-Tattoo-Color-Deluxe-Case/dp/B0055EIFC6
,I see the gun works with Solenoids.
The coil is energized with electricity, and pulls the iron cylinder core back, and forth.
This cylinder then hits a flat metal bar, and the bar is connected to the tattoo needle. (Through the various mechanism)
A) Your power adapter is an AC adapter. It converts the AC voltages from your home, or business, into low DC Voltage.
First thing to check is that it IS delivering power.
LED light lit up on the AC adapter means it is GETTING power, but we do not know if it is delivering power to the gun.
A multimeter is used to check.
Now wait a minute...............
An inexpensive multimeter can be purchased for as little as $5 to $12, if you do not have access to one.
Available in a multitude of stores.
An auto parts store is but one example.
I have seen them on checkout aisle racks, at major discount stores.
Looking at the AC adapter, what style of plug does it have, for connecting to the gun?
I need to find out what the Positive connection is, and the Negative connection.
The multimeter Function Knob is set to DC Voltage.
If just a symbol, the symbol is a dotted line over a solid line.
[IF there is more than one DC Voltage scale, set it to the 0 - 50 Volts scale.
0 to 50 Volts DC ]
The Positive (Red) probe lead of the multimeter, touches the Positive connection, of the plug that connects into the gun.
The Negative (Black) probe lead touches the Negative connection, of the plug that plugs into the gun.
Voltage is read. Don't know what the voltage is, but YOU will.
Look at the AC adapter's label.
Input: 100 ~ 240 Volts / AC 50 ~ 60Hz
We need -> Output: xxVDC @ xxA
(xxVDC is how many DC Volts.
Let's use 12 as an example.
12VDC
xxA is how much Amperage.
Let's use 3.67A as an example
3.67Amp's, or 3.67 Amperes. Same/same)
AC adapter is putting out the required voltage?
Then the switch is checked next.
Check switch for continuity.
[ Check with multimeter set to OHM's. 1K.
NO AC adapter connected to gun.
Positive ( Red) probe lead to one side of switch.
Negative (Black) probe lead to the other side of the switch.
Turn the switch to on.
If the switch is good you will get a reading on the multimeter.
DOES NOT matter at this point what the reading is.
Just matters that you DO get a reading ]
Switch is good?
Then there is a problem with one of those coils, going around the cylindrical metal bar. Perhaps a wire going to them is broken off.
Or wires in the coil have burnt.
There is a set screw for adjusting how far the vibrating metal bar, is away from the cylindrical metal bar.
Determines the distance of the flat vibrating metal bar, to the cylindrical metal core in the coil.
If this has been adjusted too tight, the flat metal bar won't vibrate.
Doubt this is the problem, or you would have stated the gun 'Hums', but won't vibrate.
[The black cylindrical things are coils. The shiny cylindrical metal objects inside them are the vibrating cores ]
I suspect the AC adapter isn't putting out any power, or the switch on the gun is bad.
Post back in a Comment, about the design of the plug from AC adapter, that plugs into the gun.
Regards,
joecoolvette
Jan 21, 2013 | Computers & Internet
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
THERE IS A LONG TIME AGO SINCE I DONT WORK WITH MY MICROTEST PENTASCANNER AND I DO NOT KNOW IF THE AC ADAPTER HAS AN OUPUT OF 9.VOLTS I AMP AC OR 9 VOLTS 1AMP DC PLEASE TELL ME WHICH IS THE RIGHT AC...
An AC adapter should output DC. The device should say next to the power plug what voltage input it requires. Also, check the AC adapter, it may say something like "Input 110-120VAC Output 9VDC".
Apr 26, 2011 | Microtest PentaScanner 350 (8180-00R)...
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
Vgn fs 980 adapter how to tell if it is not working
AC adapter? Test the output voltage.
Use a multimeter.
Stores like Radio Shack, Walmart, and auto parts stores, for a few examples have cheap one's you can buy.
About $12.
Set the multimeter knob to DC volts, and the 0 to 50 Volts scale.
The middle hole of the AC adapter plug is the Positive connection. This is where the Red lead goes.
The outer shield of the plug is the Negative connection. This is where the Black lead goes.
Look on the AC adapter for the OUTPUT VOLTAGE
(Not shouting)
Example:
I'm looking at an AC adapter for an IBM Thinkpad 370, right now.
INPUT: 100V 50-60Hz 130A
OUTPUT: 18V ~~~3.36A
The Output voltage is 18 Volts
The Output Voltage of your AC adapter should be close to this.
Dec 20, 2009 | Sony VAIO VGN-FS980 Notebook
MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Feb 18, 2009 | Western Digital My Book Essential Edition...
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
156 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
