Question about JVC TH-C5 System
Jvc DR-MV1S. All I get is "REGION CODE ERROR". It now no longer plays the DVDs it used to. It also takes a long time on "LOADING".
  • 1 more comment
  • gxstansfield Apr 25, 2009
    Thanks for the reply, but....
    Cleaned lens to no avail. Machine is now flashing LOADING all the time and I can't open the disc tray.
    where is solution no.2??
  • gxstansfield Apr 28, 2009
    No promised second solution has been sent...
  • JVC Master
  • 3,866 Answers
Here is solution number 2
Take it in to a qualified service center to have this firmware flashed, Something got locked a disk with a region lock was inserted and someone choose that region now its locked and needs to be unlocked multi region or not!! it will only cost $7 bucks to fix hope this helps!!
Rulds2008
Posted on Apr 28, 2009
  • JVC Master
  • 13,433 Answers
Please try a DVD lens cleaner on it. Is the dvd the same region as the player so its supported by the player and it should play?
Posted on Apr 23, 2009
My JVC HR-XVC27U plays some DVDs but not others. They have the correct codes, but it seems to not play the newer DVDs like Toy Story 3
see the causes and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 20, 2012 | JVC HR-XVC27U DVD Player/VCR
Tip
Jvc dvd vhs burner dr-mv1s and dr-m10 loading continues to flash
if you have a jvc dvd vhs burner dr-mv1s or the dr-m10 with the loading that continues to flash with no control of the unit at all there is the first step to take witch is a master or hard reset. done by holding the stop and power buttons at the same time for 10 or more seconds till it powers of then on again.
if this does not work or has no reaction to the unit at all them repairs will have to be made.
i have scowered the internet for fixes for this issue and have found a few interesting things but nothing concrete at all. but lead me in the correct area of the issue. although jvc was fixing these for free at one time they are no longer servicing them under their "free fix"
the problem with the unit is the power supply and although i found that easily on the web. i could not find what the exact problem was untill i did my own diagnostic testing and found that capasitor c5207 on the power supply board was bad and buldging/leaking. it is a 1500uf 6.5v @85 degrees witch i used a 105degree due to the temp and relating the issue with a bad design flaw. so use the higher temp rating one to insure long lasting use.
don't forget to preform the master/hard reset previously mentioned above and you will be back up and running in no time.
good luck......
on Mar 12, 2010 | Televison & Video
Whenever I load a rental dvd, I get "Disk Error",
This unit has had problems playing dual layered dvds and since most newer are Dl try a older rental Movie and see if that works
Mar 28, 2011 | JVC DR-MV1S DVD Recorder/VCR
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MV1S VHS Tracking
No manual tracking or if there is it wont help.either heads are worn or possibly dirty.if u open it .i assume u have.the silver drum has little notches around it.2 ,4,or 6 these are the heads.get some alchol or aftershave will do.take a peice of card playing card size is ok .must be plain not printed.apply some aftershave alchol to card not dripping ,hold card against the dum then with other hand turn the drum back and forwad not moving the card,u may damage heads.when u check card it should show some dirt reassemble and try.otherwise its museum time show the grandkids see if they know what a tape is
Jan 14, 2018 | JVC DR-MV1S DVD Recorder/VCR
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Disk error
It could be the lens on the laser. There are special cleaning disks for that.
Jun 18, 2017 | JVC DR-MV1S DVD Recorder/VCR
Code to unlock zone
Mine says it is a region 4 DVD player, but yours could be different. But referring to mine, i have played DVDs from overseas, e.g USA and KOREA with no problem. Its a fantastic piece of equipment, the JVC DR-MV1S. =)
Sep 09, 2008 | JVC DR-MV1S DVD Recorder/VCR
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Loading
ok, this same problem happened to many other jvc dr-xxxx s, i think the only answer to this would be to get it serviced or just chuck it out. the cause for the annoying "loading" blinking light is a blown out capacitator, inside the machine itself i recomend u to not try to fix it d.i.y.
Mar 13, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC TH-C5 System Logo
51 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
